Did I read on here that a Panorama is on the way with built in GPS?
Any other refreshes due?
Soon'ish ;-)
The only problem I see with this camera is that it Is too big. How do you install a 10x5cm camera on your windscreen so that it is discrete from outside. Also you have the huge suction cup to camouflage somehow. This, for me, is the only drawback with the Panorama and why I bought the Mini 0803.
Check on your PC from video clip properties.I just got my Panorama. I can see that the newest firmware is installed but how can I find out which version (15, 18 MB s.o) it is?
Thats cosidered ~12Mbps.
Gap as in missing footage or gap as in playback stops and then loads the next clip?
Gap as in missing footage. I notice at whatever I set the loop interval to, when the playback hits that frequency there's missing footage. Sometimes 0.5 seconds, sometimes 2 seconds.
Did you try the latest 5.9 version of RV? http://www.registratorviewer.com/download_en.html
(try older version as well) You should also try using DashCam Viewer. (link in my signature)
Are you using a FULL Size SD card, or microSD card with SD card adapter. There are known problems with skips if trying to use some types of microSD card + Adapter.
Is motion detection on/off?
So if you press the menu button it doesn't come on?
The "event" button will turn on the screen as well.
It just wouldn't turn the screen back on irregardless of what I did with whichever button pressed!
Whenever I encounter this problem, I am very sure it is still recording and also, upon depressing the mute button, there is still the alert indicating it is muted or not, but the screen just wouldn't come on.
At times, only when I release the SD Card from the camera, then the screen would sprung back on almost immediately indicating to please insert SD card but it is not always the case!
There are times, I did that when it happened but it still wouldn't come back on until I off the camera for hours before turning it back on, then the screen would appear again.. Sigh..
A real pain in the ass when this happens..
