Nigel
- Jul 7, 2014
- Wales
- United Kingdom
- Gitup F1+G3ꞈꞈꞈꞈꞈ Viofo A229ꞈꞈꞈꞈꞈ Blueskysea B4K
Yes, it has several options for external power on, including automatic start recording, it also has a setting for power off time, eg you can set it to keep recording for 10 seconds to avoid issues with restarting engines, and to carry on for half an hour to record parking in supermarket car parks on its internal battery.Interesting. Is this Gitup G3 Duo some new model? I cannot think of such a dashcam being available at the time when I was considering which cam to buy.
Does it have the "Automatic Switch on at External 12V Power ON" and "Automatic Turn Off at External 12V Power OFF" function? Otherwise I cannot use it as a dashcam.
Does it have a supercapacitor instead of a built-in battery? Otherwise - see above - since it will not last long in a car winter.
Currently there is no super capacitor option so maybe it is not suitable for the Australian desert or the north of Canada. In most places the camera will create enough internal heat for it to be able to charge safely in winter. Use in a parked and sealed car in summer is not advised, if conditions are acceptable for humans then it is probably OK. Replacing the battery once per year would be sensible, it only takes 10 seconds, no soldering required unlike normal dashcams. Gitup are looking into a super capacitor replacement for the battery on their F1 action camera, that may turn out to be suitable for use as a 4K dashcam, although a 4K camera is always going to have issues in a parked car with closed windows in the centre of Oz, super capacitor or not!
