Sunny
- May 31, 2014
- Colorado
- More than I can review. ;)
I tested that app and it works much better than TonView. Thanks.I found a small hack. I chose the mode 2560x1080 using the program linkinEyes. The camera began to record video with high bit-rate (18Mbit)
The 2560x1080p setting increases overall VBR to 13.9mbps, not 18mbps.
Here's file properties:
Code:
General
Complete name : E:\NORMAL\media002\20160418100912-N3935.86512W10506.64462.MP4
Format : MPEG-4
Format profile : JVT
Codec ID : avc1 (avc1/isom)
File size : 220 MiB
Duration : 2mn 12s
Overall bit rate mode : Variable
Overall bit rate : 13.9 Mbps
Encoded date : UTC 2016-04-18 10:09:12
Tagged date : UTC 2016-04-18 10:09:12
AMBA :
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L5
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=8
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 2mn 12s
Bit rate mode : Variable
Bit rate : 13.5 Mbps
Maximum bit rate : 18.0 Mbps
Width : 2 560 pixels
Height : 1 080 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.163
Stream size : 213 MiB (97%)
Title : Ambarella AVC
Language : English
Color range : Full
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 2mn 12s
Bit rate mode : Constant
Bit rate : 64.0 Kbps
Nominal bit rate : 128 Kbps
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 32.0 KHz
Frame rate : 31.250 fps (1024 spf)
Compression mode : Lossy
Stream size : 1.01 MiB (0%)
Title : Ambarella AAC
Language : English
Text
Format : Timed Text
Codec ID : text
Duration : 2mn 12s
Source duration : 2mn 12s
Bit rate : 6 554 bps
Stream size : 106 KiB (0%)
Source stream size : 106 KiB (0%)
Title : Ambarella EXT
Language : English
Forced : No
Here's a sample video at 13.9 mbps. No need to update firmware. Just set 2560x1080p using LinkinEyes app.Hi,
Could you post some video sample. I wonder the video quailty. Also how can I update the fw?
Much better VBR and it's cold weather here so heat is not an issue yet. Summer can be problem.
