@estore009 will be able to advise, it might just be a menu option you need to adjust in the appthank you for your feedback, now tell me how to fix 180 degree
Odd, how do you stick it to your back windows?still upside down
Cannot adjust in the appit might just be a menu option you need to adjust in the app
installing correctly is always a good optionCannot adjust in the app
The only way is to remove it and install it again in an opposite direction.
Just got my cam, haven't tried it yet.ok, correct estore009, i turned the unit around, in opposite direction and now works fine, thank you.
also not on back window, is being installed in a perspex box down on towbar on my ute, rear camera will be used for hooking up to my trailers.
appreciate your help.
regards
denis
Thanks that's good to know.Hi deoccultist, initially had the cable end on camera coming from left, so to correct as per estore009, i just turned the camera unit over / around as per photo.
Denis
Yeah true. I installed mine last night had it powered on to check before install.If you're not certain which way it goes, temporarily tape it in place, record some video, then view the results in a vid player. This will also let you see if the mounting location is optimum. if window defroster wires are in the view, etc.
It is an AHD rear camera, default reversed/mirror image, cannot be adjusted by the firmware! But only can toggle regular image/mirror image when preview on the camera screen;The rear camera image is a reversed/mirror image, is there a way to flip it back around?
Should be a little better if remove the tint.A bit grainy and noisy image at night in the dark through the back window, not sure if the tinting has anything to do with it...
for sure, in Australia though most cars have tinted windows, our climate is too hotShould be a little better if remove the tint.
