hi ppl could really do with some help setting up my cam as when its in parking mode its permanantly recording and looked at settings and they are not very simple to understand...also caars seem to be quite far awy,any help would be appreciated.also when i changed the settings the device tells me that they were invalid configurations
Where are you doing The settings from Its not hard really.
Put the SD card in your computer
Open the folder on the card open application Run Blackvue
Go to little cog top right
On 1st page set Time zone and fps and quality decide if you want LEDS on or off.
Set type or Time I use time.
Second page set sensitivity in each mode For motion detection in parking set nearly at bottom
Save and exit Put card in camera and turn on Will say updating Blackvue Go for a 10 min drive to let it orient itself in the world and that's it
Are you sure its wired up correctly Yellow to PERMANENT supply Red to ACCESSORY feed that turns off with ignition.
Dip switches on PM should be 1 & 2 up for 12V cutoff 3, 4, 5 up for shortest time of recording in parking mode side switch on for parking off for no parking
Any more and I will have to come and do it for you.
