cameo
The way it was described with lockups frozen behavior it sounds like a bad connection to the rear camera or faulty memory card. Did you add the included long black shielded sticker wraps around the connectors to the rear camera in the back? (shields against EMI) Test with the rear camera cable left unplugged for a while and see what the results are in single-channel mode. Test with another memory card as another confirmation test. If you're using the 3-wire hardwire kit, it could be sub-optimal fuse slots were chosen for ACC/BAT wires. CANbus causes havoc like that if wrong ones were used. If you have 3-wire SGDCHW hooked up let us know your year make model vehicle, and we can run it by our global installer for advice. Also confirm you are connected to a factory ground point. Start with all this and we can go from there.
Yes, I installed the rear camera cable in a supplied sleeve.
I don't have another memory card of a suitable size. After all, you shipped this unit with what was called "a high reliability card".
There were two working fuse set choices for a 3-wire connector kit as confirmed on Mustang forum. As described extensively earlier in this thread, I had to shave off the tabs from fuse connectors that you sent me because they were incompatible with Ford Mustang GT Convertible. In the process of trying to fit them, I ruined one set of possible fuse sockets in the the fuse board so I ended up using the other set. Again, there is back-and-forth between me and you about this issue at the beginning of this thread, as Street Guardian wasn't aware at the time that Ford used incompatible fuse sockets in some of its cars do to a leeway in the format. In the end modified connectors seemed to work - at least every time the unit experiences a fault, the power box pilot light is always on. (If you actually have the proper connectors that don't require modification and can send them to me, I would be grateful since it would eliminate one potential problem point.)
I will try to run the unite without the rear camera. Do you think a BIOS update would be useful?
