not sure how it would go in the heat of an automotive environment thoughSome clear tape like that was pushed on a LCD screen, the last time i was in the building supplies store.
yeah I've used the clear VHB tape also, works great, not sure how that reusable tape compares though, the fact that it can be removed and reused though makes me think it might not be the best choiceI've been using a non-3M clear VHB tape for years to hold various cameras around the car, and some fixing jobs around the house. Looks like I've used 15m of the stuff since 2013! I'm placing another order today.
Clear tape does catch the light more than black tape from certain angles when seen from outside. I usually mount on the frit or headliner so the tape colour is barely noticeable.
Oh dear. It's no longer available. I think it's time to switch to black tape.I've been using a non-3M clear VHB tape for years to hold various cameras around the car, and some fixing jobs around the house. Looks like I've used 15m of the stuff since 2013! I'm placing another order today.
Well, it is quite short. E.g. if people are mounting Mobius behind the mirror, surely this can fit as well?Then it would protrude more into the cabin and I doubt it could be placed behind the review mirror.
The Mobius by itself has a considerably smaller front profile than almost any other camera one might use as a dashcam. It is however longer than some cameras in the front/back direction, plus it does not come with a mount.if people are mounting Mobius behind the mirror, surely this can fit as well?
I really hoped for a "bullet" design - basically the same size, but with lens on the edge (where Street Guardian logo is) and a simple rotating joint in the mount. Which would make mount just a bit more complicated, but the whole front footprint would reduce significantly. Plus, moving the joint to the mount (instead of between the camera and mount) would allow, possibly, to remove several mm from top and bottom. Basically, turning it into a much skinnier shape of Mobius. (perpendicular to the front plane)
What Mobius are you referring? I googled "Mobius dash cam" and only get results for action cams and yes a small front facing but over all "Outer Dimensions: approx 71mm(L)*35mm(W)*18mm(H)" And this does not include any sort of mounting that will add to the overall size. I am just asking, not disagreeing, as I don't know what camera you are referring.Well, it is quite short. E.g. if people are mounting Mobius behind the mirror, surely this can fit as well?
I may be biased, as for many years all cars that my wife and I had all had sensor block behind the rear-view mirror. I thought this becomes more ad more common.
Have a look at 3rd post in this thread. https://dashcamtalk.com/forum/threads/sg9663dr-installations.42612/#post-516749What Mobius are you referring? I googled "Mobius dash cam" and only get results for action cams and yes a small front facing but over all "Outer Dimensions: approx 71mm(L)*35mm(W)*18mm(H)" And this does not include any sort of mounting that will add to the overall size. I am just asking, not disagreeing, as I don't know what camera you are referring.
We just had almost no space behind the actual rear-view mirror on those cars, as they all had a sensor blocks in that place. (rain sensor, traffic sign and vehicle recognition cameras etc, which is sometimes a VERY useful "crap" ) Not the sensors in the mirror - the sensor block is usually glued to the windscreen. Again, like in the photo in 3rd post that i mentioned.I think you mean all cars you have had, when you put something behind the rear view mirror it blocks sensors in the rear-view mirror that are facing forward?
Instead of temporarily attaching removable dashcams to the rear side windows which can open/close using suction cups or nano-magic thick gel tapes, now I will almost permanently attach the dual remote lens dashcams directly to the fixed non-opening rear quarter glass panels via the OEM supplied simple 3M dual sided self adhesive tape sort of like below, but of course with the lens pointing out of the glass instead of at us.
When will the SG9663DR be available with 512 GB Down Under so I can purchase two (2) pairs of dual channel dashcams???
I also have numerous friends that I can refer for more SG9663DR sales; they always follow my advice when it comes to motor vehicles.
PS
What model triangular wedge remote lens dashcam is this below?
I think this is even better than the tubular design, and this triangular wedge design is what Dashmellow wants???
Is this triangular wedge design compatible with the SG9663SDR?
This triangular wedge design is much more individual styling and easier to centre the dashcam for a centred image.
However, on second thoughts, the triangular wedge design is more ideal for the steeply raked front and rear windscreens, while the tubular design is still more ideal for the more vertical side windows?
Would it be possible to order the SG9663DR's with these triangular wedges, rather than the tubular design???
Ahh "sensor block" I understand now. I took it as blocking in the way of, not block of sensor(s). LOL yes "crap" with no disrespect to those with newer cars. There is a way much better chance in surviving or even avoiding an accident with all the tech in the new(er) cars than in an old 2003 whatever. New-old, all have good points and bad. I had to have my windscreen replaced 2 years ago for a rock chip, cost me all of $250 usd to replace. I think they charge that just to re-calibrate the built-in camera when they replace the windscreen not to mention the cost of the glass and installation of all the stuff (not crap) attached to it. My guess is any new car with lots of tech, it will cost between $1,000-$2000 for a new front window replacement so one better keep a low deductible. Lastly, never have I had anything go wrong with my basic car of now 18 years old. We will talk in say 10 years (if you still have the same car(s), lol) as that is about how long a computer is good for and a new car is a computer hurtling down the road. To sum up as I have written before,...If someone wants to "give" me a new car I will take it over my old car, but if I have to spend $30-$60 thousand usd for a new car I want it to last me way past the manufacture bumper to bumper warranty.... say at least 20 years.Have a look at 3rd post in this thread. https://dashcamtalk.com/forum/threads/sg9663dr-installations.42612/#post-516749
You can spot the lens of Mobius cam (action cam, often used by enthusiasts in remotely controlled aircraft models. Or as a dashcam), from driver's side, just under the rear-view mirror.
I see it. Yes small, but maybe you mean just above the the rear-view mirror.
what is the make and model of the vehicle? cabling may be an issue with your proposed mounting location
we can't buy suitable 512GB cards in Australia so not something we can offer at this stage
wedge design wouldn't be suitable for the side windows as pictured
The cable would need to go through the factory rubber grommet in the door, depends which method they use if that is easily doable or not, anything Toyota is generally easier to work on though so you might be in luck
In the US they use the Samsung cards, if parking mode is a consideration I would always suggest using High Endurance cards as the better option, currently that limits you to 256gb though
