Deacon
- Dec 18, 2016
In what ways have performance been substantially improved that we should look forward to?performance is one of the main reasons
it's a single board design versus two PCB's in the old model, the ribbon cable that connects the two boards is a weak point, there other benefits also but they're all incremental, together it adds up to a better end resultIn what ways have performance been substantially improved that we should look forward to?
So, in theory, it would be possible to use the DR main unit and 2x DCPRO rear cameras?...
Can we then conclude the camera cables for the DR and DC are the same diameter? In the picture the cables appear to be 'substantial' and that was the biggest issue I had in installing my DC and X2PRO rear cams. It will give me pause if the DR cables are larger than the DC.yes that works fine
They say the camera adds 10lbs... So since you're using a camera to take pics of a camera, that's 20lbs. And when you add 20lbs (sorry, ~9kg) to a cable that probably weighs less than one pound, well.... π π€£Cables are not thicker than the existing ones, going by some reactions so far it seems everything looks bigger in pictures [emoji51]
you can take your tent back inside now πjust got it
I have mine on the dash by the steering column, will be different in every vehicle, just keep in mind the mic is in the remote, you also have file save function and can turn the wifi on/off using the key so you want it somewhere suitable to the functionality, the light can be disabled in the menus if you don't want it flashingWhere are people mounting the remote. I'm not creative and looking for suggestions. π
yeah I think laying it all out and planning your install before putting anything in is always going to be a good idea, the install is a lot more involved that a typical setupFirst i would figure out where to put the main unit, and then see what options i have for the button with the wire length it have, one should be able to gauge this first without actually having to install anything permanent yet.
you mean the 3 people who have this in hand?lolWhere are people mounting the remote. I'm not creative and looking for suggestions. π
I plan on under cup tray in center consul for head unit, there is lots of space, easy to remove cup tray. Just need to verify there is air flow, if not then back side of glove box, it pivots down with release of upper tabs. Wherever it ends up airflow (not in front of climate vents) and access is what matters to me. Many options for remote..depending on length of cables and main unit placement.We are waiting for feedback to see what customers decide.
no, the mount is solidIs the DR tube design more prone to shaking when going over bumps compared to a DC? I had a Blackvue before and I didn't feel it was very sturdy.
Damned studios, I had such a cool looking SentryMode screensaver in my Tesla Model 3, they had to go and file a cease and desist against Tesla, so Tesla changed the SentryMode icon.Gear selector knob,,,,,,, to a Dane that might be something a NASA official say, we just get a stick to pull and push.
I think i would like some slack in the wires, so where i install it i can still take it out and read the screen / operate it / access the memory card, but i also think that is something i can do just fine, and a foot or so of slack i think is all i need.
If you are a fan of the film 2001 a space odyssey, you could have a little "fun" with the red button π
