alexp999
- Dec 17, 2015
- United Kingdom
- SG9663DC
Okay that's fine. Just checking it wasn't a bugYes but it's not set up for logging
![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
Ok, interesting that the speed shown is similar to your actual speed (first two digits) might add weight to the suggestion @Dashmellow made earlier about the speed anomaly
I was on Beta 16 then. On 20 ATM. That's the only time I've ever seen a spike.
@jokiin
Can you copy the release notes to your first posts? I love to know the changes/release dates for each file without having to download each time![]()
Don't think so. The other day when mine spiked at 15,580 KM/H I was doing 47 KM/H
One of the interesting things about the 425 MPH readout on the GPS is that I was traveling at about 41/42 MPH for the seconds before and after that capture. Could it be that the 425 MPH reading was a decimal point out of place in the firmware's GPS calculation?
Hey Rick, here ya go..Hi @normm do you still have the file this screenshot came from? would like to get a copy of it if you do
https://drive.google.com/open?id=0BzeDfFbaaetZbnRZaG9INzQxZ1E
Strange though that after saving the fragment, the max speed is now 2473 km/h instead of 15,580...
If you need it a bit longer sing out..
Edit: The spike only shows in Registrator viewer and happens at 14:53:20
yeah if you have the full clip is better, Registrator Viewer will manipulate the data when you cut a fragment
Okay, I'll have to upload tomorrow from work as I record in 5 minute segments and this 'glitch' seems to happen right at the end of one so I'll upload the two files (the one it happens in and the one that starts 1 second later) but that's 1.2GB in total and that will kill my data allowance (I'm on 4G here, no ADSL or cable)
yeah tomorrow is fine, engineer won't be able to check it until then anyway
if possible can you upload to www.mega.co.nz as we can access that from China, google, dropbox etc are blocked, also please zip each file (doesn't save any space but helps if we need to resume a download if it times out) and upload each file individually
thanks heaps
