glypter
- Feb 22, 2016
- SG9663DC
Beta 1.34Twhat firmware version are you on currently?
Beta 1.34
have just added updated version to the beta thread
Just finished my install with hardwire kit today and updated to the most recent firmware, 1.33. I have yet to do but some stationary testing but it seems parking mode is functioning based on what I saw on the card. That said, with the three wire kit is there a way to disable in the camera settings for times when it is not necessary (my vehicle lives in a garage). Also, when I pause recordings to go into the menu I get constant beeping which I don’t remember my old camera giving me. Is this normal functioning to just let me know recording has ceased or is there an underlying issue?
I'm still on 1.34T and I've found that today it seems to have cut off within an hour. I should probably check the battery voltageInstalled 1.33, formatted my card afterwards, set it to 6 hour shutdown timer, 5 fps, 3 wire parking, voltage cutoff was 12.2V and about 2 minutes of parking mode footage was recorded
OK. Will do that tomorrowplease update to the version posted in the beta thread, there are still some known issues with the version you are using
Installed the new 1.33 update from beta thread. Did not see any difference, getting short 2-3 minute parking lapse and then unit is shutting off.have just added updated version to the beta thread
Should be set at 12.2.what voltage setting are you using?
I'll set it to the lowest it can go. I have a 2017 Civic EX-T so the battery should be relatively new. Wasn't aware that the voltages could differ in different places in the car like that.try setting it lower, the voltage at your fuse panel can be lower than at the battery already so you may hit 12.2v reasonably quickly, particularly if it's a smaller battery
