evmedievalol
- Nov 7, 2015
Perfect. Ill order the one that i linked.
It should work great!
there is a USB service port on the camera but the auto start stop etc is only available from the 12v input
Then any of these 12V power banks should be fine, as you say, so that makes it a lot easier than the typical 5v camera.
for this yes it's a lot easier to deal with
I wonder if finding a suitable cable in the proper length that fits these 12v power banks is an issue?
you may need to make your own cable, I'd assume the camera comes with some sort of output connector to use with the 12v socket, they normally come with a range of different adapters, the camera uses a 35135 plug and socket (3.5mm OD, 1.35mm pin) which is the same plug used on older model Nokia phones so reasonably easy to pickup a suitable plug if you needed to make up a lead
https://www.amazon.com/gp/aw/d/B007...tte+female&dpPl=1&dpID=315aYcPDbpL&ref=plSrch
Could please confirm that this will work with battery pack i linked previously?
It's been working great so far. About 28 hours straight on no problem.
Would it be ok to use the input insert on the Powerbank to charge it from the car using cigarette male adapter while outputting 12v to my dash cam?
....My new battery pack lithium polymer 20000 mha? works for about 48 hours in cold weather. I was expecting little more..![]()
mehh it's more like little less than 24 hours in cold weather now that i checked again.I think 48 hours is reasonable for 20000mAh (20Ah) battery.
I've generally found that cams use in the region of 400mA/h (0.4A/h) which is what you're getting.
Simpler, lower-spec cams can use as little as 150mA/h while more complex, higher-spec cams can use as much as 600mA/h (0.6A/h).
A car battery is typically about 45Ah (45000mAh) so will run an average cam for about four days and a simple cam for nearly two weeks. Some cams state their typical power requirement in their manual/spec sheet.
Do you buy to try every electric thing on the market ?they have 3 different models and I bought one of each to try, just this one failed, the others work ok, I have better power banks though
Do you buy to try every electric thing on the market ?![]()
