is there anyone used that before,i can not believe the ads,thank you for advance,if you can give me some advices.
galaxy tab 4 7.0 hülle
used which before? and not believe the ads about what?is there anyone used that before,i can not believe the ads,thank you for advance,if you can give me some advices.
When will you have stock of the G90-7S?
You should contact with the seller where you buy the dvr.
Refer to the experience, first and second issue can be improved by SW.
As for IR light, if you know dvr well, mostly light doesn't work good (frankly speaking).
You have accept this, or comparing with other dvrs, it is almost the same.
Your problem i had connect your seller to solve. HS600B product doesn't have screensaver function,and it can't shut down with the engine automatically.Some of our products have this two functions,but unfortunately, HS600B hasn't.
So if you can't shut down the dashcam,its battery will drains out,and you have to set date and time every morning.
well not sure what you're selling it as but it's not a dashcam then if it operates as you suggest
