- Aug 11, 2015
- China
Por favor, póngase en contacto conmigo en tony@sjcamhd.com si pedimos un caso separado. Sírvanse también proporcionar su número de orden. Gracias
Nice to have official representative here. Welcome!
Can you reveal an image sensor?
I know its probably a repack of SJ4000+, but I truly hope I am wrong.
Have you guys thought of adding Sony sensor? The one in SJ4000+ is quite bellow the average for the price.
@sjcam_official Can you confirm that M10+ has Gyro and non Gyro camera?
If so, how can people know which is which? Is there any label on the packing?
Mine seams to have better stabilization compared to SJ4000+ (no stabilization), but nowhere it says Gyro or whatsoever.
Also there is a bug on both 4000+ and M10+ when used as a Webcamera, plug them in and you will see.
Thanks, good to know.There was only one batch of M10+; All have Gyro Anti-shake.
I did an update, but can you please check if the file you uploaded is the right one, as it says September 7 when I updated, and on your it says September 8. I do see "Stabilization" if thats what you mean?Please update the firmware to the latest version of firmware:
Well you do not know your own product as well as you should, as each and every of your cameras does have a web camera (PC camera) function, when plugged in the PC, you can chose from Mass Storage and PC Camera. Latest SJ4000+ and M10+ do not work on Windows 10.None of our cameras support web camera. Where did you see this?
Have you ever tried to plug the camera inside the PC? Any of your cameras, once they are plugged, you will see. I am certainly not guessing, it seams that you are not familiar with a product you are selling. All of your camera have a PC function.B) Actually, none of the NTK96660 cameras support web camera. I am not sure where you saw that or if it was an guess as previous models did support. Please let us know if you do saw conflicting information anywhere. thanks
Yes, the stabilization is the best bit of the M10+, I tried it on my bicycle yesterday with very acceptable results. Except that the bike tyre disintegrated!Nigel, I am not that much into hardware and tearing cameras apart, but I believe you are right. I actually thought that the side buttons (WiFi and Nav) are going to get loose first. No idea what happened there. I was hiking yesterday with camera attached to my chest mount most of the times. Perhaps waterproof case is pushing it too hard?
Anyway, since I dropped it, it can be that as well. No way to know.
I must say I like the stabilization so far. Weather was terrible, so I had to use waterproof case.
Ah ****....
In the middle of my testing, M10 Power button broke down. I think me dropping it caused this. Waterproof case did not help much, so this is my own fault I guess.
I tear it apart, and one of the connectors got broken. I tried fixing it, but I do not think I will be able to do it.
@sjcam_official do you know where I can but the front board? I do not think I have the right tools available to fix the connector problem.
