V1.2.4 20160112
1, Fixes waterproof housing has Black Corner in sensor issue
2, increase the machine can be 64G 128G EXFAT card formatted as FAT32: EXFAT insert DV, DV will prompt “card error, please format the card” and then after the machine format, you can use
3, modify the replay did not take the question of the role rewind
4, modify disconnection problems caused by APP
5, optimization of color reproduction
6, to improve camera sharpness, contrast, noise reduction photographed
7, noise optimization 2K resolution
8, optimize clarity 1080P60
9, optimize battery life
10, the recording volume increases 9,10 Level
11, increase the exposure time setting options: You can select AUTO, 1/30 seconds, 1 second, 2 seconds, 5 seconds, 10 seconds, 20 seconds, 30 seconds, 60 seconds. Note that the exposure time option in the camera and burst interval when no action, the software will perform automatic exposure time
..lets see if the corrections take the wanted effect.
To correct the black corners you must decrease 170fov how will you fix that housing and lens problem otherwise? This would be not the best way to cut the fov.
