- Aug 11, 2015
- China
@sjcam_official
Tony, can you give here an official statement regarding audio issues? Tell us which cameras are affected, are they still in sale, what happens if a customer receives one with faulty audio.
From what I understand its a hardware issue, so firmware update can't do any good.
I am in the middle of article, and I just need to know what is going on. I do not wish to write something without knowing your side of the story.
So it would be good to know what caused the issue, can it be fixed easily if a customer is tech-savvy, how are those faulty unit handles, are they withdrawn from stores or are they still available.
BUG REPORTS:
- 64GB memory card - playback does not work with 64gb cards, works with all others.
- You have TV Out mode twice, once in "modes" and once in "settings"
- Video Mode Pal/NTSC makes zero difference to video resolutions, so why do we need it?
The three things I noticed were the colors are on point (easily matched with my Sony Nex F3), overall image looks better and my 64gb card works now without having to do a FAT32. I think the 1.2.4 firmware is the best so far. I didn't check the sound, but indeed there are two more levels. I'm anxious to try out the 4k.
-Nate
@sjcam_official
May I get a reply about the audio and units affected, reasons etc.
@sjcam_official
BUG REPORTS:
@Pavle, i really don't have this info. People speculate that they can tell the batch by using the serial numbers but we do not have a system in place that can confirm batches yet.@sjcam_official Are you ignoring my questions on purpose?
Can you reply to the above questions regarding audio issues and serial numbers/batches affected.
Glad to hear your SJ5000x Elite is now set 🙂Just to share, i had seem like solved the "bright/dead" pixel issue after upgrade to V1.24. With latest V1.25 firmware with "engmode" method, SJ5000x Elite become better and acceptable now, thank you.
Hey guys, can somebody tell me why are micro SD cards get so hot in these cameras?
I am using samsung 64 gb pro plus cards and they are usually pretty cold, but these cameras somehow make them so hot in 5-10 minutes one really starts to wonder...
Probably the camera's PCB radiates heat to the adjacent components instead of conveying it away so it may heat up the SD card slot along with the memory card in it.
Ok looks like I solved the audio problems in my sj5000x elite.
http://savepic.ru/8522458.jpg
http://savepic.ru/8583901.jpg
Maybe try turning Gyro off and recording at 1080p @ 60fps. things like Wifi can be turned off when not needed as well.Hey guys, can somebody tell me why are micro SD cards get so hot in these cameras?
There is a new SJCAM SJ5000x v1.3 firmware: The new SJ5000x v1.3 firmware adds a ton of new features. Check out change log here: http://goo.gl/uoRmOjOk looks like I solved the audio problems in my sj5000x elite.
