Unit Specs
- Bought unit from here - unit had GPS, no internal or external card.
- Opened unit (voided warranty )
- Placed SanDisk 32GB Class 10 card in internal slot (unit had slot from factory)
- Placed SanDisk 16GB Class 10 card in external slot
- Flashed with 20131202 firmware
- Formatted both internal & external cards using 20131202 firmware
TEST #1
Pointed cam at a (turned on) TV, the cam was recording non-stop for over 16 hours.
It recorded till the 16GB card was full then kept recording erasing the oldest.
Ended up with 6:20:33 of recorded video & audio - no errors!
TEST #2
Removed the external card and let cam run non-stop for over 14 hours.
That should have been enough that the 32GB (internal) card was full and the unit would have to erase the oldest.
Plugged it into Windows 7 PC - ended up with 3:07:14 of recorded video & audio - no errors!
But wait!
I was able to record 6 hours on the 16GB (external) card, shouldn't a 32GB card have recorded more than 3 hours?
Discovered that windows shows the capacity as being only 14.8GB. (Before inserting the card in the camera it was formatted by Windows and showed the full 32GB capacity)
Doesn't explain 1/2 the recording time (3 vs 6 hours) for 92% (14.8 vs 16GB) of capacity.
Interesting that the only internal option (from where I bought mine) is 8GB.
Could this be a firmware issue?
For now I'm going to set this capacity quirk aside.
TEST #3 (
Pending)
Return unit to car w/GPS mount and factory power adapter.
