Maddox said:
Not sure if your still stuck on this. But I use registratorviewer v5.2 and the gps maps all work automatically. It’s the accelerometer data that doesn’t load unless I attach the gps track log manually which is a pain. Is this what’s happening to you or is there no data at all?
My original firmware had a gps open or close option. Would be nice to get it back again.
Think I’ll wait a while before installing the newer 20130905 firmware if it just ups the bitrate.
Regards
If I drag and drop the .MOV into Registrator Viewer 5.2, all I get is the video. The GPS Map shows no route at all. Check out the screen shot photo I atttached on the previous page 46. Here's the direct link:
viewtopic.php?f=9&t=1001&start=450#p25050
If I right click on the file and select attach track, then browse to the assosiated .log file, the Map, Route, and even Speeds shows up then. I'm guessing the Speed is a calulcation based on location & time but it works. I just don't want to have to manually attach the log file to each 1 minute clip painstakingly 1 at a time. You then have to manually group the files after that as well. In the past this attach process happened automatically. (drag drop .TS resulted in all GPS data shown)
The log attachments actually works automatically in version 5.0 but you get Scrip errors. (so it's only good to use newest 5.2 version anyway) I messaged Vadim and here's what he said.
On Mon, Sep 9, 2013 at 7:16 AM, Vadim
> I have more information for you. We just discovered GPS data is
> auto loaded in version 5.0 (but won't auto load in 5.2)
Yes, old version don't know about internal GPS tracks and load only
external .log file.
> speed is just a calculation based on time/location?
May be.
> I keep getting an OpenLayers script error with this version though. I'm on Windows 8 Pro x64
Don't use OpenLayers - it is bad platform, use LeafLet...
rrrsea said:
for the gps issue,
if there is a problem for it is always on,I have asked factory to make a newest one to with the gps setting on it.
I am not sure it is good for you or not.But if the firmware published.I will notice everyone here and will send to you
If I can have a download place ,I will let everyone know
irononreverse said:
I received the firmware from Betterking. It's the same file that's been shared on here. 20130903. It looks like there might be something wrong with my device because it still won't update.
Looks like he's updated his inventory to include the 8gb internal memory version as an option.
http://www.aliexpress.com/item/Mini-080 ... 79514.html
Thanks for helping us out guys, who ever gets an update please share right away so we can continue testing until we are finally happy
