- May 14, 2013
- Oakland Park, Florida (USA)
- StreetGuardian.CAM Amazon.com
Hi guys, I have a problem with my cam that I thought was limited to 0509 firmware, I have a 32gb class 10 sandisk card the red and gray one. When it reaches about half way full I get low write speed and I think it says storage low it flickers on and off quickly and stops recording. Does any one else have this problem on a 32gb card? If I format the card it seems to carry on again until around the 2 hours remaining point. FYI I have the givoe gps model with no internal storage.
Try another card, the Sandisk U1 cards can be a bit finicky
You might also want to do a full format in the PC using the Panasonic SD formatter program, format again in the camera afterward
As you're probably aware a quick format doesn't erase the card completely it just removes the index information, if there's a bad sector on the card it will trip up when next writing that sector
I think the best all rounders are probably Samsung, in my experience at least
Sandisk I personally haven't had an issue with but they do get a mention from time to time as being problematic in some cameras
Bad news, I have the SAME problem! After the card is full, it will randomly power off after only a few minutes. If I format the card via 0801 it's good again until it's full. I was formatting often during my first week of play, so only now ran into this again since I'm leaving it alone in my car. I'm on firmware 20130903 still.
I tried using the Panasonic SD formater utility (full format), and then re-formated it via the 0801 menu after that. I let my camera record all night last night. I put it back into my car, and bam shuts down after a few minutes.
What's next? Should I try to format the card with a different Cluster size? (and then NOT re-format it in the 0801 itself) If so what size should I try first?
guiformat.exe ?
http://disk.yandex.com/public/?hash=DQ3pHb5OwYTcNW/cpsh10hMuAWG3ha/0fBTkVARKCpQ=&locale=ru
HP Disk Format Tool?
http://www.softpedia.com/get/System/Hard-Disk-Utils/HP-USB-Disk-Storage-Format-Tool.shtml
Here's the card I'm using
SanDisk Ultra 32 GB MicroSDHC C10/UHS1 Memory Card with Adapter (SDSDQU-032G-AFFP-A)
https://www.amazon.com/gp/B009QZH7BU
Should I order a Samsung instead? If so which one?
If you look at the instructions.
http://dashcamtalk.com/cams/mini0801/Mini 0801 User Manual.pdf
Page 4 says
"Please use high-speed TF card meeting the specification of TFHC. (CLASS 4 or above, Class 10 may cause some problem because the speed of card is too fast, it is better not us class 10 card)"
Did anyone here actually buy a class 4 32GB card?
No, I've never heard anyone that put the CX4 firmware on the Mini 0801 yet so I didn't want to be the first. I'm not even sure if it will have English then!Hi, JazJon did you test the procam cx4 20130911 firmware? I can't remember if you did and what were the result.
