Hi, I got into the sub-menu and started to make some adjustments. For a novice such as myself I found it a bit nerve racking trying to make the adjustments. Finally figured out you need to jump back and forth between the menu key and the mic key to make changes, would be nice to have that in the guide. I even looked on youtube to see if there might be a 'how to' but no luck (touchmoan has done this with other units).
Just a suggestion for us noob's to have a description of each sub-menu item along with how to make the adjustments, not only will it be handy in the original set-up but also later on when you might need to make changes. Those of us in adjustable time zones will need to make changes twice a year with enough time in between to need a refresher.
On another note, I ordered a couple of 10ft. long cables (USB 2.0 A Male to Mini-B 5pin Male 28/24AWG) to connect to a dual usb cigarette lighter plug. I did this since I plan on putting a second cam in the rear and wanted a connection to a single lighter with dual usb adapter (
). Saves me the trouble of messing with the fuse box and hardwiring each unit, with my planned set-up the lighter will only have power when the car is running and I won't need to worry of a drained battery.
I will download the viewer today and go through another learning curve, hopefully I'll be ok after that and will go out for a ride to test everything out. Taking me a little longer than most but like I said I'm new to all this.
Incidentally, is it ok to use a Transcend 64gb microsd sdxc class 10 card in this unit?
Sorry for the size of the picture couldn't adjust it.
Thanks.
Fred
