- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
the timezone setting is all you should need to make, the clock will set automatically around 10 seconds or so after it gets signal, if it takes longer to get signal it may not update the time until it gets to the next recording segment (3 minutes default) and it will check it and resync within around 10 seconds in to that segment
if you've reset defaults best to set your timezone and let the camera update the clock to ensure this is working correctly
once defaults are reset everything will work but at a minimum you would want to change the timezone and the frequency setting, those are the only two localized settings you need to change, anything else is personal choice of course
