- May 14, 2013
- Oakland Park, Florida (USA)
- StreetGuardian.CAM Amazon.com
@Leeeeeooooo I just sent you a PM check your inbox.
Let us know where you purchased from so we can have someone follow up with you
I purchased from Pier 28.
Two quick questions for the GC pros here. First, does the camera alert you in any way when the SD card is full, or does it simply stop recording? Second, I use the SD card that came with the camera as a primary and carry a spare SanDisk Ultra Plus 16 GB as a backup. When I initially used the spare for the first time, I formatted it and everything seemed to be working fine. On several subsequent trips (and randomly), I noticed that the record light was not flashing and the screen showed a "memory error" message. I was able to remedy the situation by powering down and un/reinstalling the card. Does this sound like an out of spec card? Thanks in advance.
So the camera will even overwrite copy protected files (i.e. "saved clips")?
Roger on the SanDisk incompatibility. I knew there were a few brands that didn't play well. So, Kingston is the preferred brand?
So if the protected files cannot be overwritten, what then, happens if the card's capacity is consumed by protected files? Does it simply stop recording? Does the camera give any sort of indication of low memory capacity?
I'll look into the Lexar. Thanks!
I get a TON of clips of bad driving where I live. Because of its form factor and ease of operation (and the huge capacity of the card ) I sometimes forget to dump the files. Generally, I can go about a month, sometimes more, before I have to transfer clips to the PC. It isn't a huge deal, I was just wondering how the camera dealt with that scenario. Let's just call it my contribution to the development process.
Thanks!
My questIon there is, if you are having all these events why are you leaving them on the card? Would you not want to get the card out to review and save on your computer as soon as you can? You could delete them off the card then.
