What is that, did they send you an SMS?Yiepieeeh!
they weren't thinking when they named it, were they?
"ActionCam Hater"?? π
Could you please expand on this Nigel? Why is a 16MP sensor necessary for the combination of true 4K and gyro stabilization?Maybe they needed the rest of the pixels for the gyro stabilisation, and it didn't have enough processor power left to scale the remainder up to 2160?
That doesn't give much room for the stabilisation though! You really need a 16MP sensor for true 4K and gyro stabilisation.
Okay, that makes sense.might be possible with a smaller sensor, basically though the stabilisation function needs more pixels than the resolution you're using as the active area moves around on the sensor, it's not fixed
With a 12MP 4:3 aspect ratio sensor, when you chop the top and bottom off to get 16:9 aspect ratio you end up with 8MP. 4K video has 8MP so a 12MP sensor has zero space around the image for the gyro stabilisation to work in. If you are going to use a gyro with a 12MP sensor then you will have to enlarge the image using interpolation, so you will not have real 4K video. With a 16MP sensor you have 4MP of spare pixels so can use the gyro and still have true 4K video.Could you please expand on this Nigel? Why is a 16MP sensor necessary for the combination of true 4K and gyro stabilization?
Thanks Nigel, that helps explain it.πWith a 12MP 4:3 aspect ratio sensor, when you chop the top and bottom off to get 16:9 aspect ratio you end up with 8MP. 4K video has 8MP so a 12MP sensor has zero space around the image for the gyro stabilisation to work in. If you are going to use a gyro with a 12MP sensor then you will have to enlarge the image using interpolation, so you will not have real 4K video. With a 16MP sensor you have 4MP of spare pixels so can use the gyro and still have true 4K video.
Now try and find a 16MP action camera with a gyro that does true 4K!
