The ones that I listed are Hetai for sure.Sonique said:Are you sure about the fact, that behind every seller on ebay there is the Hetai company?
Mtz said:No, they are only using Singapore Post as shipping method. Is the best cheap shipping method to send items from China, better than HK Post and much better than China Post. Sometimes I received in one week something from China using Singapore Post. I think the SG post have all offices there in Shenzen and the stuff is not going to Singapore, but leaving China directly.
I have an FedEx item from Korea and form Seoul was going to China (Shenzen) then to Germany and from there will go to Romania. The SG Post shippings came to my country directly from China judging on the tracking number.
If you are living in EU (except UK) and order bigger values (under 4KG) try to ask sellers (not the #18 seller because he is using only SG Post and the value is not big) to use Yanwen because is possible to not pay custom taxes because the shipping in arriving first in UK and from there is going to your country and UK is considered inside EU.
enjoy,
Mtz
My cam isn't working. After i received the camera i immediatly tried to update the firmware, which resulted in the cam shutting down after 1 second. I tried everything, resetting, formatting the sd-card on my computer, nothing worked.
So i contacted the seller, hxelpro360, which replied that i could send the camera back so they can check it and i would get a replacement.
My concern is, should i send the camera back and wait for another one to arrive (about 5 weeks?) or should i try to get a refund, and buy the now more expensive camera again. When it really is the Hetai company behind these sellers, maybe i won't be the fool after all. Maybe someone already had similar problems that led to a replacement?
regards
Gazza said:Purchased from foxoffer after reading all the problems folks were having with eBay and amazed it arrived so fast from Hong Kong to the UK.
Works well and so far, no problems at all and very pleased with the quality of sound and video.
Thanks for all the information and advice I gathered from this forum.
Only problem I am having is trying to edit the files in Vegas Pro 12. None of the files will load and YouTube doesn't seem to like them either in their basic format.
Can you guys give me some pointers on how you manage the files.
I've tried all the 'fixes' to get them loaded in Vegas Pro with no success.
sekazi said:The setup I have is a USB cable to a USB port in my center console. I have a 2013 Ford Focus if that matters.
When it first did this I hooked up the original power but I did not leave it on. The reason I opted out then was because my 12V power does not cut off when the car is off so that means I would end up draining the battery.jokiin said:sekazi said:The setup I have is a USB cable to a USB port in my center console. I have a 2013 Ford Focus if that matters.
sounds very much like your battery is not being charged sufficiently, revert to the included car charger is an easy way to confirm if this is the case or not
