Troubleshooting 70mai A810 (T800E) 4G Hardwire Kit – Persistent Flashing Red Light (Kena Mobile SIM)
lilquack
Milan
Italy
Hi everyone,
I’m looking for some help with my 70mai 4K Dash Cam (A810/T800E) setup. I live in Milan, Italy, and I’m having trouble getting the 4G remote monitoring to work.
The Setup:
  • Camera: 70mai A810.
  • Hardwire Kit: 70mai 4G Hardwire Kit (UP04).
  • Installation: Done by a professional auto electrician.
  • Status: Basic functions work perfectly. It records in parking mode, and I can connect via the local Wi-Fi hotspot to view footage.
The Issue:I recently bought a Kena Mobile SIM (TIM network, Italy) to enable remote monitoring. Despite my efforts, I cannot get a 4G connection. The LED on the 4G Hardwire Kit flashes red, while the manual/tutorials indicate it should turn solid green once connected.
What I’ve tried so far:
  1. SIM Prep: Inserted the SIM into a smartphone first. I disabled the PIN code, verified that data/roaming works, and tested the APN.
  2. APN Settings: I tried both the default TIM APN and the specific Kena Mobile APN (web.kenamobile.it).
  3. Connectivity: When I start the car, the dashcam still only works via the local hotspot; the 4G remote features remain inactive in the app.
My Questions:
  • SIM Compatibility: Could the issue be that it’s a "Voice + Data" SIM rather than a "Data-only" IoT SIM?
  • Installation: Is it possible the kit is wired incorrectly, even though the parking surveillance mode is working fine?
  • APN/Settings: Are there any specific settings I might be missing within the 70mai app to "force" the 4G activation?
  • 5G SIM in 4G Hardware: The SIM is a 5G-enabled card. Could this cause handshake issues with the 70mai 4G modem?
I've been trying to fix this for a week with no luck. Any advice or suggestions would be greatly appreciated!
Thanks in advance!
Before you go any further check that the dashcam you have supports the up04
The T800E I couldn't find any proof that it is supported. It doesn't support Battery Voltage Monitoring which is a feature of the up04
The A810 depends on the exact model you have. The A810 says it does support it.
  1. Sim compatibility
    1. May be but I have a voice and data sim and it works
  2. Installation
    1. If the surveillance mode is working then I presume the Acc wire is connected correctly.
  3. APN settings
    1. I didn't add an APN I just let it do it itself. Important note - My sim and up04 failed 3 times. I turned everything off and tried again and it worked.
    2. check this video it starts at the 4G
  4. 5G SIM in up04 works. I have a 5G SIM in my up04 and it is working fine so I don't think that is the problem.
What is important is you get a flashing green light.
If you see a flashing green light I am pretty sure that it means the up04 is talking to the internet (ISP) then it only needs the dashcam to bind to the up04.
See the video as I walk through the process.
I wonder if the SIM has to be recognised by the Telco before it will allow anything further to happen. Rebooting everything a couple of times might be enough to force the Telco and up04 to handshake.
