Goof! Thanks a million. I used the "latest one" the 2016 file from freskdesk and it "seems" that I got rid of the file corruption issue! Woohoo! I tried the 15mbps one and that did not cure that issue. I'll test it throughout the week and report back. This is awesome news... for me at least.Try that link
http://www.filedropper.com/2014081311
This is a link to a newer firmware from a different vendor, not sure if this has the last file saved corruption issue.
https://wr24support.freshdesk.com/helpdesk/attachments/8002055112
Do you know where I can find the older firmware?I have no issue with 2014.0813.11.
You can flash a previous firmware, no problem.
you mean that, probably there should be title menu of cam
This is the same issue I'm having.Hi jokiin,
I'll learn their firm wit (bluskysea) and they don't experience power cuts while cranking.
My car is Renault Fluence 2011 model and power cuts is lower than 1 sec. while cranking.
It's happening instanttaneousnessly.
Do you and your friend (who doesn't have issue) have the same Firmware version? This would help me troubleshoot it down to a hardware issue.
Please post a link to your current firmware that fixes the issue.Hi Quaters,
I've installed 2014.0813.11 firm and it's solved power cranking issue. I can share with you.
The important thing is I've new problem with cam after install above firm.
Cam stop when SD card full. It does not write on continuously.
