Looking through eBay at all the different dash cam options, I'm bugged that you're forced use an all-in-one unit if you want HD video and that none of these can cleanly support additional cameras.
Looking at the 'professional' setups used by law enforcement, it seems that they're using a standard IP camera with what looks like a small windows embedded computer hidden in the trunk.
I like the high quality and reliability of an IP camera, along with being able to take advantage of available add-ons like lenses and remote control capabilities. I don't like the cost, power consumption, and maintenance of a car PC.
Has anyone tried using one of these simple standalone network DVRs to run an IP camera as a dash cam?
http://www.ebay.com/itm/4CH-Full-D1-H-2 ... 3f2697d5b2
http://www.ebay.com/itm/8channel-Networ ... 4d0e545385
Assuming you used an SSD or SD to SATA adapter, it looks like you could even keep a setup like this running while parked overnight. I also like that some of these units also let you tie in an analog camera (so you could record from a built in rear view camera)
Any thoughts?
Any thoughts?
