IMHO suck cups suck. I've had dozens and NOT ONE will stay attached for a year, and most fall off every week or day. Vantrue gives you a couple plastic sheets to stick to the window, and a 3M pad on the camera mount to stick to the plastic sheet. VERY SMART!@Jeff_Vantrue
The E360 looks like it would make a good travel / temporary dash cam for rental car / vacation.
1.) Do you guys have any plans to add a suction cup mount for the E360 like you have for other models, (E1, E2, E3)?
2.) Does the E360 generate two separate files from each image sensor, or just one file of recorded footage?
3.) Does the E360 require specialized / proprietary software to view the recorded footage?
4.) Does the E360 have both H.264 & H.265 Video Codecs?
In 360º mode you get ONE video file with all the data. You can configure for 4k front only, or something like 2k+2k limited "front and rear". Nice options.
No. One of the reasons I'm dumping all my TypeS crap is that DashCamViewerPro Just Works® with the files straight out of the vantrue e360! Hooray!
No. You get what you get and you don't pitch a fit. ;-p
Code:
General
Complete name : 20241121_150054_00135_N_A.MP4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/avc1/mp42)
File size : 208 MiB
Duration : 1 min 0 s
Overall bit rate mode : Variable
Overall bit rate : 29.1 Mb/s
Frame rate : 30.000 FPS
Encoded date : 2024-11-21 15:01:54 UTC
Tagged date : 2024-11-21 15:01:54 UTC
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5.1
Format settings : CABAC / 1 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 1 frame
Format settings, GOP : M=1, N=30
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate : 28.7 Mb/s
Width : 5 184 pixels
Height : 1 944 pixels
Display aspect ratio : 2.667
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.095
Stream size : 205 MiB (99%)
Language : English
Color range : Full
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : avcC
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : mp4a-40-2
Duration : 59 s 840 ms
Bit rate mode : Variable
Bit rate : 64.2 kb/s
Channel(s) : 1 channel
Channel layout : M
Sampling rate : 16.0 kHz
Frame rate : 15.625 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 469 KiB (0%)
Language : English
