If you are having any problems with your A119S, upgrade to Firmware V2.2.Hello together with which firmware with the Viofo A 119s since you are satisfied? In which firmware can you read the license plate well?
I'm only concerned about license plates next to my car or within a car length.Hello together with which firmware with the Viofo A 119s since you are satisfied? In which firmware can you read the license plate well?
You'd want to be on the latest firmware (2.2), includes important bug fixes.
Depending on what time of the day it is and the lighting conditions, number plate capture can be a hit or a miss.
I'm running 2.1,i have no issues, the
Change log:
- 1.Added: Finally fixed camera freezing while showing XXXXX on screen.
I never had that, are there any other improvements that should move me to upgrade?
Yeah man, I know, that's what I said, you are repeating me.....? Hahaha big Q is SHOULD I UPDATE if I don't have that xxxxx freeze thingie?Bug fix to be precise.
2.2 also shows
Change log:
Seems that finally tamed it with 2.2
2.2 also shows
Change log:
Be sure you are manually defaulting the camera in the settings after updating. This helps ensure to clear any leftover values from the previous firmware.Just got this camera freezing with the XXXXX a few days ago while on 2.2 Updated firmware to the latest 2.4 hope this fixes it. Seems like once a month this is happening to me now that I am out of warranty
2.2 also shows
Change log:
If I recall, you still experienced the screen issue with V2.2 (not with the XXXXXX's) correct? I remember Viofo saying it could be the ribbon cable causing it and they were going to send you a new ribbon cable (maybe I'm not remembering correctly). Did you ever change the ribbon cable and did you ever experience the screen issue again?2.2 and now 2.4 have been rock solid for me. As CYA mentioned, reload 2.4 and reset to defaults and see how it goes.
Viofo A119S - parking mode doesn't work | A119S | 1 | ||
R | VIOFO A119S let me down. | A119S | 3 | |
T | VIOFO a119s FIRMWARE | A119S | 72 | |
Viofo A119S Official Beta firmware | A119S | 57 | ||
VIOFO A119S Modified Firmware MODs Archive | A119S | 1340 |
