Good 6Vf sharpness comparison, good parking lot for tests, from these clips Strong Sharpness works better. Quality suggests you own Lens1 in plastic holder that has shifted focus to center leaving edges slightly blurry with slight alignment too far right leaving blurry-left edge. Using 6Vf Normal gives good center focus but not enough for edges, using Strong improves edges but starts to blur center.Please see my 2 clips from today with 6Vf an
strong sharpness: https://drive.google.com/file/d/1eKXVB1DcXgZVviMSfR_KMO5yr_TRf_9n/view?usp=sharing
normal sharpness: https://drive.google.com/file/d/1MdYdO0ksy1Oms7ZnvhKKsIaSVjlBmD55/view?usp=sharing
It seems the video is faltering a bit. Maybe the bitrate is too high?
or is it just my eye?
What sharpness do you recommend?
After that it will be time to test 6Ns I guess.
If you press MUTE that setting is stored and remains MUTED until press again, its the same as MENU > Record Audio > off.I found a bug in 6Vf firmware (but maybe it is connected with my power issues with broken capacitors again, I'm not sure).
After using the mute button for the videos yesterday for the first time, the camera is muted every time I start the car again. If I turn the microphone on again - it lasts as long as the camera is on. When turning it off and on again - it's again muted.
It just helps to restore the setting.
Of course I un mute it after taking the video clips. Normally I have the microphone turned on. So if course I restored the mute setting.If you press MUTE that setting is stored and remains MUTED until press again, its the same as MENU > Record Audio > off.
Very good and accurate assessment of the common 'blurry-on-the-left' Lens focus issue. As you noticed much can be determined from RAW video footage.Your lens is OOF on the left hand side sir.
Very good 6Nr Beta test footage, agreed these clips aren't the same IQ as other test clips, without Contrast control all we can do is lower Saturation since no one wants Brightness lowered. Adjusted Edge and Saturation. thanks for these side-by-side comparisons, very helpful. This next MOD will be very different more extreme levels.Firmware: FWA119S_MOD-6Nr_v4.02+26Mbps+Sharp575860C+Sharp140B+Edge146+Brite127+Sat124B+Sat20A+DCTeam
1080p 60fps
60hz
CPL=On
ev=0
WDR=Off
Both cams set to STRONG sharpness.
Lens 1: Strong Sharpness
Day Sun Behind
Day Sun Front
Night
Lens 2: Strong Sharpness
Day Sun Behind
Day Sun Front
Night
Thoughts:
Still liked earlier fw versions better. L2 was esp. washed out on contrast with white objects. Like the License plates of Red Light Running Truck and Night when stopped at redlight. L1 was a little bit better with this but still not to my preference. I do lean more on the side of legibility of Number Plates rather than other IQ parameters.
Great pre-6Ns wet-snow footage, with only +2 Edge there is improved fine detail, clip suggests +2/4 still needed, revised 6Ns = +10 and will be messy. Expect 6Nt sometime today once I see some samples (raining here again). thanks for the early footage.These might actually be from an older version of 6Ns? I had it installed yesterday morning and not sure if you did additional changes to it since then. You can definitely notice that the crispiness has improved compared to 6Nr. This is using soft sharpness as well.
1080p@30fps - CPL - EV 0 - Sharpness Soft - 60Hz - WDR Off
The weather was also complete trash during the day, so I tried to get footage that was a clear as possible. Most of it was just dirty snow showers and road mush shot at my windshield.
Snow Cloudy Day - Highway
Snow Cloudy Day - Residential
Didn't have much usable night video, mostly drove on empty roads. Did make a quick compilation of this guy though... One of the reasons for getting a dashcam.
So how many things wrong can you see this guy doing in like a 5 minute distance?
Night - This Guy
Great pre-6Ns footage, that second A119S Lens2 is much better than older Lens, these clips suggest +2 Edge sharpness and -2/4 Saturation. All clips were saved 1080p in 30fps, when you view RAW 60fps some player Apps will stutter, try a different video player for 60fps or tweak settings of current one for better performance, or just use 30fps. thanks for sharing.Some test clips with new 6Ns firmware.
It have highest resolution with 60fps and lens2 (my second A119S).
parking lot, slow driving
Normal sharpness: https://drive.google.com/file/d/1fsNJWxWOj8qstdKrh1i3pbFl1i7yYGGS/view?usp=sharing
strong sharpness: https://drive.google.com/file/d/12MGcfr4-6tinhKpOJ6H2tI3eaoZ6RXlR/view?usp=sharing
normal drive along the road:
https://drive.google.com/file/d/155UPWc5GzNzipvOic5xEd36gsWYGP6Wk/view?usp=sharing
it looks like the video falters, is the bitrate too high? or is my eye too accurate?
WOW! Great 6Ns night footage, am working on A119Pro Stable version and this looks very close to that IQ almost couldn't tell them apart. thanks for sharing, I must know what is the Edge and Sat values on this 6Ns firmware?6Ns - Night Time - 1080p@30fps - CPL - EV 0 - Strong Sharpness - 60Hz - WDR Off
https://www.dropbox.com/s/ahnsjkw5g1gno3a/2018_1103_200106_023.MP4?dl=0
WOW! Very Great 6Ns night highway footage, thanks for sharing these clips, I must know what is the Edge and Sat values on this 6Ns firmware?I use vlc and think it's the best.
Which player do you suggest?
You like the image quality?
I have some more videos, this time in the night. It's uploading at the moment:
#1: https://drive.google.com/file/d/1FKqHKvRKfeHBSNuRjNoU6UMVteWP-uzR/view?usp=sharing
#2: https://drive.google.com/file/d/1F3zrDoqNNk87SbkvFgeUuEu6qb-T8Z1q/view?usp=sharing
#3: https://drive.google.com/file/d/1mK9mW8PlIrSlEQQ8i2va51UcirHjyF2c/view?usp=sharing
How to see it?WOW! Very Great 6Ns night highway footage, thanks for sharing these clips, I must know what is the Edge and Sat values on this 6Ns firmware?
I need comparison samples using the revised 6Ns with Edge158+Sat118B.
Making revisions to 6Ns - download this fresh copy
FWA119S_MOD-6Ns_v4.02+26Mbps+Sharp575860C+Sharp140B+Edge158+Brite127+Sat118B+Sat20A+DCTeam.bin
Download > https://drive.google.com/open?...xDs6K4LS1E3lc5OGYUY_TCt8yfyo7O
