lufa6977
- Jul 22, 2024
- Virginia, Shenandoah Valley
- United States
- Vueroid S1-4K, Viofo A129 Pro Duo, A229 Pro, IR, Telephoto
Other way around? I think it's more about binding the dashcam to an HK6, not binding an HK6 to a dashcam. I've only got one HK6 on hand though so it'd be up to others to verify the behavior when you have multiple HK6's present.
Semantics. Regardless, the A329x should only listen to the respective HK6. Will other A329x 'hear' that same HK6? Yes, I expect they will. Can the A329x in your other car also be bound to that HK6...I'm not sure, as I am unaware of the level of intelligence in the HK6 and how discreet it is.
Is the Cut-Off Voltage field always available in the A329x, or is it grayed out/not seen if no HK6 is detected? If you see the Cut-Off Voltage field in the A329x that does not have an HK6, you could try to disable it to see if the on-screen voltage disappears.
