CDNinHH
- Jul 14, 2013
- Thailand
- A118C MG600G (JooVuuX returned)A119 Shadow 1S
Ok, finally found a bit of time to check out the sample I received from Viofo.
First I want to say that I'm only a consumer, not an expert such as MTZ or Jokiin on dashcams, so my observations are from that perspective.
I have the A119, A118C and a Shadow 1S all mounted in the car at this time. I also have a Matego Blazer ( Mg600G) mounted as a rear view camera.
Some quick observations comparing the 3 front cameras:
Motion detect:
A118C: Poor, you need to virtually wave your hand in front of the lens to activate.
A119: A bit better than the 118, but still seems to be not very sensitive, it did occasionally activate as I walked directly in front of the cars bumper. It then stays recording for 59 secs if there is no further movement.
Shadow 1S: It's motion detect is too sensitive, seems to be activate very easily and then records for 12-15 secs only if no motion detected.
Now some night observations:
A118C : as we know is very poor
A119: I am finding that I have numerous hot pixels shown against the black sky, but the quality is pretty good.
Shadow 1S: This is the model that has the low light mode that physically changes a lens filter when it detects low light, you can hear it clicking when it switches modes on the audio track. When in low light mode the video is in black and white.
EDIT: as mentioned by another sampler, if you have the beep function enabled then whenever the camera is NOT recording, the REC led flashes and the camera beeps....very annoying if you have motion detected enabled as whenever there is no motion detected it emits a constant series of beeps. The only fix is to disable beeps. This needs to be addressed in the next firmware.
Here are some screen shots:
Motion detect:
