vvs49
- Jan 8, 2015
- Ukraine
There is no stamp entry, but there is a log entry in the upper left corner !!Front:, Interior:
Correct.There is no stamp entry, but there is a log entry in the upper left corner !!
Where does it say beta?That's beta for you, lol...
The 3-in-1 is stuttering when I view on YT, whereas the individual files seem OK.Running latest beta firware - Wifi connection fixed (error in last one):
Still out of sync audio with rear and interior when added with front.
RAW files linked - YT files shown.
Forgot to reverse the rear camera in individual files I uploaded!![]()
Yes, it's just the compilation for some reason.Looks ok if you download the front file.
Maybe the timestamps in the files are slightly different and the video editor has tried to align frames by time instead of frame number?Yes, it's just the compilation for some reason.
Where did you get the firmware from? I'm running 0906 on front and back.I tested parking mode yesterday with the latest beta FW (V1.0_0820 + Rear V1.0_0906). I noticed that the parking files took up all the available space on my card. There were no normal driving files left.
@VIOFO-Support @viofo Please can we have reserved space for normal driving files? Perhaps 30% or even 50%?
I also noticed the following bitrates in low-bitrate parking mode:
Front camera - 6.5Mbps
Rear camera - 12Mbps
Interior camera - 4Mpbs
Please reduce the rear camera bitrate in low-bitrate parking mode.
Direct from Viofo. I believe it is only suitable for some of the test samples.Where did you get the firmware from? I'm running 0906 on front and back.
The final version will be improved as we changed the lens and IR LEDs for the inteiror cam.The interior IR at night shows very brightly now since the update above.
Will the IR LEDs still be 940nm wavelength?The final version will be improved as we changed the lens and IR LEDs for the inteiror cam.
Yes, we also optimized the interior lens cover, so it can get more IR lights in.Will the IR LEDs still be 940nm wavelength?
I see no more stuttering, missing or duplicate frames with this firmware. Good Job!Latest firmware for T130: https://drive.google.com/file/d/1G18QLjYbIj9DT-2KYaCEzNLADnxClXmf/view?usp=sharing
1. Optimized IQ,
2. Support long press MIC + LOCK button to disable / enable interior cam.
3. Bug fix
