.......With single cameras i have used my mobius and joovuu X camera as they have the smallest head on profile.....
On my hatchback the heating wires don't go near the top of the glass since you can't see up there from the driver's seat, the camera is mounted as high as possible using a sticky pad and looks through the gap above the heater wires, there is no issue, I have a mini 0906, however my hatch is around windscreen angle instead of near vertical so may not be relevant.Thanks for the info guys.
My front camera is a mini 0801 that I bought like 4 years ago and still going strong. I am not opposed to buying another from the mini series if that's the best option.
I like the A118 or A119 cameras but I am not sure whether they can be mounted if the glass is vertical?
Also the inside of the window has heating wires so I don't think I can apply the adhesive over those wires, won't the heat just melt the adhesive causing it to fall? Maybe I can use several small adhesive squares positioned between the wires.
I thought maybe many other people might have hatchbacks so I was wondering what they did.
Also,add our B1W to this listMobius, Joovu, Viofo WR1. Anything small and compact really. Would suggest you don't really want a screen on a rear cam as could be distracting.
my coworker bought an A119 for his trucks rear window which is vertical. seems to work fine for him with the thicker mounting plate.Thanks for the info guys.
