The USB cable in this case is really JUST for power. The actual gps data goes direct from the gps antenna in the mount to the camera via the little pin connectors on the camera side of the mount. The USB cable has nothing to do with the gps at all.not about the power its about the signal from the GPS
Thank you for ur information. I have a friend who owns a Garmin 35. The GPS is built in and He tried to use a regular power cable and the GPS did not work until he used the power cable that was supplied. He called tech support at Garmin and they said he had to use the power cord that came with the unit as it is compatible for GPS.The USB cable in this case is really JUST for power. The actual gps data goes direct from the gps antenna in the mount to the camera via the little pin connectors on the camera side of the mount. The USB cable has nothing to do with the gps at all.
I haven't seen the edges of the gps mount to see if it has a mini USB socket. @CaptureYourAction - can you check and maybe post a picture of different angles of the gps mount? Would be great if it had the power plug on the base so you could quickly remove or install the camera without having to fiddle with a cable connection.
Did u find that the video was a bit hazy (blurry)? Maybe It's my eyes but it seems not to be so sharp. Did you remove the protective plastic covering the lens? It has a good color but not as sharp that I had expected. I was comparing it side by side to the video of the Street Guardian SG9665GC V2Here's a recent A 119 video from Viofo:
Ambarrela in A261 render yellow, novatek in 119 render green.Viofo posted that clip 2 days ago ... ( I will be getting mine Tuesday: Prime shipping with Amazon 2 day... what a difference from gb 33 days!)
I am getting the A119 mostly for the Capacitors, to see how it compares to Battery type... and I am done buying anymore, until I can justify spending $300 on OPIA 2
Here's another compare between A119 and A 261 (I have one, which I can compare with) :
I find the A261 is a little sharper (pic), and A119 has better colors, but a little darker.
To buy before it's all gone by Monday:
Only 7 left (yesterday they had 13 listed)....
or this from unknown place:
by Blueskysea
Price: $96.49 & FREE Shipping
Note: Not eligible for Amazon Prime.
Estimated Delivery Date: Aug. 10 - 26 when you choose Standard at checkout.
In Stock.
Ships from and sold by BAIKLOV.
It sounds even scarier than GB.
A261 have a bigger FOV than 119. But the detail of A261 has as fully as 119 has.
Do you have another footage ? night footage in side by side comparission ?
why ? But the A261 has a better image quality ?But this is my best clip: almost perfect for the price:
yes... here it is:
Hmm, the night time video quality of the A119 doesn't look that good to me compared to the other one. I thought it would be a big improvement over the A118C, but doesn't look like it to me. Not sure if I'm going to regret the order that I already placed.
V | Does A119 V2 have a rechargeable RTC battery? | A119 | 15 | |
H | Unable to upgrade Firmware | A119 | 4 | |
R | Is the suction mounting adapter still available for A119 V3? | A119 | 2 | |
Viofo A119 AV Out cable | A119 | 19 | ||
DASHCAM REVIEW Viofo A119 Simple Neat Capable Capacitor Cam | A119 | 5 |
