- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
nice job!
Further to my post back in May, (and big thanks to MiiHere for giving me the idea), I've finally taken some pictures of my install.
First off, the original install, just sticking the mount's to the window:
Not very discreet! I had originally hoped to mount the camera at the top of the screen next to the rear view mirror, behind the "dots", without using the cable tidy. Unfortunately this resulted in some of the rear view mirror housing being in frame, so wasn't acceptable. Hence the location I've chosen to avoid that, but it just looks ugly.
So I wanted a discreet solution that looked as OEM as I could get, and I knew that meant extending the "black" section where the rear view mirror is. It was MiiHere who gave me the idea to use vinyl.
So here is my first attempt:
(ignore the white paper) - you can see this would hide the camera mount etc, but in my opinion (after I'd applied it) looked silly. I hadn't got it lined up straight and I hadn't gotten all the air bubbles out (this was actually completely black window tint film....in the first picture you can see two black squares on the top left and right of the screen....these were my little "test" swatches of different materials to see which I wanted to use!).
So I decided the black had to blend in with the original section. Thats what the white paper is....one of many templates I made with paper, so that I could just cut the vinyl to the correct shape.
Here's the finished article:
As you can see, the camera peeps out at the bottom. The black vinyl isn't the exact same "shade" as the OEM black section, but in real life it blends in quite well, and it doesn't stand out...lots of cars have these black sections on their screens now, so at a passing glance, you'd just assume it was original.
I got a stone chip that needed repairing and the repair guy initially thought it was genuine... I've still got the template so if the screen does need replacing I can easily do another one (now I commute 100 miles a day, I'm expecting more stone chips!...and now I commute 100 miles a day is the reason I got the dash cam....so many miles = so many opportunities to need it!).
When I first tried installing the vinyl I just tried sticking it to the glass.....it was impossible to get it in the correct position, so I used some water with "washing up" liquid mixed in and then it was easy to slide around to get the correct position and then "squeegee" the excess water and air bubbles out. Also note that in some of the pictures it looks like some of the vinyl hasn't stuck correctly - thats just the muck on the outside of the windscreen that isn't in the wiper path and also the "dots" around the original black section - they are flush with the glass, so not a problem to stick over, and until these pictures I hadn't noticed them that obvious....so in reality they aren't a problem.
From the driver side it looks like this: (apologies for the image being grainy...had to lighten a lot in photoshop to show any detail)
And the passenger side:
The pictures make it look quite big and obvious from inside, but it doesn't seem like that when in the car, i.e. not in your face.
In the drivers view picture you can see the GPS unit in the bottom left of the dash. I had initially put it at the top of the rear view mirror housing (tucked in behind the mirrors cable, just visible in the first two pictures) but you aren't meant to put it so close to the camera (interference?) so I moved it.
Because of how far down I had to mount it, the cable tidy doesn't go all the way up to the headlining, so you can see the wires at that point, but I'm happy with that....call it a compromise.
Taking pictures of the screen is quite difficult with glare and reflections....and also I could've washed it first.
Note my skater dude friend....he's been with me through about 5 cars! (thats 5 car changes...I haven't written off 5 cars!!!!)
Hope you like.
What is your car make / model / year ?
Good solution to use tinted film ! [emoji106]Hi, its a 2012 BMW X1, pre-facelift.
(Nikolai - I haven't forgotten the other project, I just haven't progressed it for a while).
Updated my post to include vehicle details and screen grab to show the field of view I get.
Seems to be yet another example of overly dark SG9665GC footage on a sunny day.![]()
That may be the truth, but I didn't include that image to show any such issues, I included it purely to show the field of view. Lets leave the that conversation for the other thread.
Nice. I wasn't aware of such a rule about placement of cameras here in the UK, although I agree that some locations are just dangerous if they block vision (the number of cars I see with sat-nav units stuck to the screen below the rear view mirror is amazing, and I've even seen some with the camera in direct line of sight!).
I guess MOT time will be the test. Nice tidy cables in that last shot!
Whats the joystick in front of the handbrake? Is that to control the in car things like sat nav, radio, menus etc?
You may be good to go with yours since that specifically says it applies to suction mounted devices....The rules on mounting dash cams in the UK can be found here: http://suction-mounted-car-cameras.blogspot.co.uk/....
Thanks.
It says that if the suction mounted camera protrudes more than 4cm into the wiper clearance area that it is illegal. Mine isn't suction mounted, so I wonder if that is a get out clause for me, as mine is clearly over 4cm into this area.....
If the UK is like the USA the law only applies to what it includes. What is not included is considered to be excluded on purpose. In time the legislature may change the wording but for now if you apply adhesive under a suction cup you have a glued on mount which is not covered under that law. If you screw the mount to your roof it should also not be covered by that law. I have no idea if other laws might apply or not. Looking up your laws is a smart move.
Dashmellow is correct, but the way our US law system functions, if it is not obstructing your view (such as behind the mirror) a strong argument can be made that the law in itself is wrong or is being wrongfully applied to you. You may have to go through the appeals process to get there though, which won't be easy or cheap. We can question the validity of any law here, but that may not be possible elsewhere. That's how Glik v Cunnife (the ruling which allows public videotaping of government officials) came about.
My approach is always to 'fly under the radar' and not be noticed, and if I happen to be discovered then to be as nice and non-confrontational on the scene as possible which usually lets you get by. Save the fight for the courtroom then have a good lawyer blow them away there
