Why doesn't this camera have a micro USB port?
DashBoat
Viofo A129, Auto-Vox M3, Mobius Maxi
Does anyone know why this new camera still ships with a mini USB port?
I wasn't too happy about having to 'downgrade' my permanently run cables (but did anyways), especially since my next dash cam will probably have a micro USB port.
doema543
I thought most if not all GPS and dashcams use mini usb? In terms of having a secure plug, the mini usb is definitely more snug/tighter than your typical micro USB. I'm sure there are also other reasons I'm not aware of.
DashBoat
DashBoat
The popular mini series offers micro USB.
I actually looked through many white papers and spec sheets showing the difference between micro and mini interfaces, but can't find a single reason why one wouldn't go with micro USB.
I'm mostly wondering about why this option was chosen, it doesn't change my opinion of this camera either way.
DT MI
Michigan
More than my wife thinks I need.
...I actually looked through many white papers and spec sheets showing the difference between micro and mini interfaces, but can't find a single reason why one wouldn't go with micro USB.....
I would then offer that there's also not a single reason one wouldn't go with mini USB. Just saying...
jokiin
Too many ¯\_(ツ)_/¯
Mini USB is more reliable when using the 10 pin variant, if it's power only using 5 pin Micro USB is fine but it limits some future options
DashBoat
DashBoat
There is tho. Micro seems to last longer. Mini seems to be designed to fail at the port, while a micro failure usually means just a new cable instead of new device.
Micro uses less space, plus it's easier to find accessories.
doema543
There is tho. Micro seems to last longer. Mini send to be designed to fail at the port, while a micro failure usually means just a new cable instead of new device.
i would say that for the purpose of a GPS/dashcam, I'm glad they're stuck with mini USB as the micro while smaller is too fragile in my opinion to be used on a device that's always going to be mounted on a car.
Nigel
Devon
Gitup F1+G3ꞈꞈꞈꞈꞈ Viofo A139ꞈꞈꞈꞈꞈ Blueskysea B4K+B2K
The "popular mini series" is available in both forms, I have 1 with micro USB and 1 with mini USB.
I think the micro was designed for use with phones where it gets a lot of abuse and is likely to be accidently yanked out sideways so is designed to fail before the socket in the phone gets damaged, thus protecting the phone. The mini is more suitable for permanent installations and has a much stronger plug, it also has more pins so can have extra functions.
DT MI
Michigan
...Micro seems to last longer. Mini seems to be designed to fail at the port, while a micro failure usually means just a new cable instead of new device....
Any empirical evidence to support that opinion? I have multiple devices with both mini and micro connectors and have not had a failure with either.
Robert F
I have no evidence, but just feel that a larger mini USB would fare better in a dashcam than micro. Most micro connectors on phones are relatively reliable as the phone is usually stationary (i.e. on a desk/bedside table) when charging.
With a dashcam, the unit itself is moving around with the cars vibrations. A micro to me would feel like it could wiggle out. USB-C would be tighter still I guess.
iptelman
Canton, Ct
DAB-202
Mini USB has 5,000 cycle life while micro USB has 10,000 cycle life.
Robert F
Interesting. But For a dashcam I don't think that part is as relevant - if you're plugging in the cable 5,000 times I think you're doing it wrong :) For a cellphone its certainly important with daily charging, but most dashcams are 'permanently' wired in.
I believe micro-USB also wears better as mentioned, i.e. its the cable that will break and less likely the internal connector.
abarth
SF bay area, California
SGZC12RC░░ mini0805░░ viofoA119░░B1W
jokiin
Too many ¯\_(ツ)_/¯
also more likely to have someone try and insert it the wrong way around and mash it in the process
Gibson99
Houston, we've had a problem, Texas
Yes
Actually it's not. At least based on the one laptop I've used that had type c for its power connection. It felt about the same as plugging in a regular USB type a (what most people probably think of as a standard port -what comes on a thumb drive or the other end of a phone's charger cable). There was no click as it finished plugging in but it also didn't feel like it would just fall out either. Plus type c is about twice as big as a micro b connector (the standard plug on an Android phone).
DashBoat
DashBoat
For what it's worth, I've had several mini USB ports fail on me, even on devices that aren't frequently plugged in/unplugged all the time. In fact, on one device, the variable cable strain was enough to trigger the port failure.
I haven't had a micro USB port fail on me yet.
But anyways, I was merely curious about the reasoning for selecting mini USB. I don't think any extra pins are used, but maybe mini USB is cheaper to implement? Who knows. Since the manufacturer is monitoring this thread, I was hoping they would have said something.
I find it hard to believe this is a concern since this would only happen once in most cases (the USB port will be fine, even if you push hard, unless you're The Hulk), and if a person can't pay attention to details like that while installing a dash cam in their vehicle, they probably shouldn't be installing any hardware to begin with.
The Type-C port definitely feels much tighter on Nexus devices when using high quality/OEM cables. Some of the cheaper non-compliant cables do seem to be a little looser, but they aren't following spec to begin with.
jokiin
Too many ¯\_(ツ)_/¯
Have had people push the connector clean off the PCB they've forced it that hard, don't underestimate what happens out there
dash riposki
Isaan
Thailand
too many
Try plugging in a micro black USB cable, in reduced lighting, on a black cased item. :)
I try to restrict the 'stuff' I use on the road to things that use a micro or mini USB. That way I can charge stuff easily, use a few common charging devices, including in hotels.
DashBoat
DashBoat
I have a lot more issues with the self-propelling gravity-defying micro SD cards than screwing up my micro USB port ;)
SawMaster
SC
Numerous and ever-changing
You're either not trying hard enough or you're intelligent and careful ;) My problem with USB mini is that I have several PS's and devices which are supposed to be 'standard' and compatible but can't be plugged together. Maybe I'm not trying hard enough :eek: Gonna get my sledgehammer, brb :p
