BCHobbyist
- Jan 19, 2017
- Vancouver
- Canada
- A139 3Camera A129Duo-8WL A129Pro-4K A119V3 A119S-6Vk DCTeam
Why Reset Default Settings after an Update?
Any device with BIOS / Firmware saves user settings on a chip, when the Firmware is updated the saved user settings are cleared forcing user to re-configure all settings.
However if the Firmware Update adds or removes a feature (numeric parameter value in a specific field and address location on the chip) it doesn't always match the pattern of user settings from previous firmware. An overlap of fields can occur causing rogue behavior. To eliminate conflicts and corruption I recommend always RESET the device to Factory DEFAULT Settings this will cause the Dashcam to restart with the new parameter framework for currently loaded BIOS / Firmware. This ensures long term stability and rewards you with the wonderful VIOFO intro once again.
We all want improved performance, fixes and extra features which adds to the coding complexity where rogue errors will occur.
With the rise of Ai each of us must do our part to crush rogue code from all our devices before they merge into SkyNetMatrix and enslave us all . . . always Reset DEFAULT Settings !
Browse all BCHobbyist WorkShop videos:
https://www.youtube.com/user/bchobbyist
