when i format my C drive there is allways somthing i forget
You should change the HDD structure. Personally I like more to have the HDD partitioned based on type of files I have on it: OS, documents, programs, media files
downloading as 6 megabytes a second
Lucky you
; I'm at 1 Mbps at its best, but not today because since two days ago my modem went crazy again: connecting/disconnecting ...
So i will start over it seem and just choose the 64 bit which i have been on since it came to be for windows computers.
No reason for 32bit
I might be in for some tweaking when i get under the skin of this OS
Give a chance to
http://www.classicshell.net/ , unlock apps from taskbar, TaskBar->Never Combine, Toolbar->NewToolbar (quicklaunch buttons) ...and you'll get something similar to Windows XP in the end
I'm using 8.1; I have no problem at all (only some weird problems with some virtual applications, windows audio device graph isolation and safely remove for external HDD). I don't know why people are complaining. Also, you can make it to look almost identically with 7.
I only have one machine capable of handle the 10
https://www.microsoft.com/en-us/windows/windows-10-specifications#sysreqs
Processor: 1 gigahertz (GHz) or faster processor or SoC
RAM: 1 gigabyte (GB) for 32-bit or 2 GB for 64-bit
Hard disk space: 16 GB for 32-bit OS 20 GB for 64-bit OS
Graphics card: DirectX 9 or later with WDDM 1.0 driver
Display: 800x600
to remove OneDrive and all the other modern apps, aka BLOATWARE/shovelware/CRAP
If they don't start with the system, then there's no problem. Also, startups, taskschedulers can be disabled.
why does a stinkin DOWNLOAD tool need admin rights? and why can't i just download the ISO like i did
Probably because for the "Update" option it uses "C:\Windows\SoftwareDistribution\Download" while only for ISO you can chose were to save the downloaded packages.
I'm guessing it's because it needs access to admin restricted areas to verify you have a valid activation key and to kick off the upgrade process.
Tested on 3 days left virtual machine of Windows7x64 (which has been "fixed" initially but it seems that it got sick again
); the download works, 2% ...but I had to stop it (my internet connection can't afford this right now; maybe all the night). I think it's because for update it will need to save the files in Windows folder.
The TP ISOs don't require a valid existing OS so there's no issues with releasing a generic ISO install.
About the license:
Can I reinstall Windows 10 on my computer after upgrading?
Yes. Once you’ve upgraded to Windows 10 using the free upgrade offer, you will be able to reinstall, including a clean install, on the same device. You won’t need a product key for re-activations on the same hardware. If you make a meaningful change to your hardware, you may need to contact customer support to help with activation. You’ll also be able to create your own installation media like a USB drive or DVD, and use that to upgrade your device or reinstall after you’ve upgraded.
Does it mean that initially I have to update my OS, then I could reinstall it from scratch because my hardware parameters were already saved on Microsoft servers ?
If it's like this, I don't really like it.
that apparently they're allowing even pirated copies of win7/8.x to be upgraded for free.
"almost" ...they'll become unlicensed versions.
i spoze they'll need another method for people who don't know what to do with an ISO, and apparently windows update is that mechanism.
There is also the option "Update".
