Stefán Gyula
- Jul 16, 2015
- Hungary
I' use the v1.2.12 custom fw.
How can I use same setting in timelapse video? (2k 35mbps)
zip file is still broken, can you please check and upload it again? Thanks!@Mcpackin, yes they are compatible, but you have to remove or change the lines for the bitrate and resolution. Thes are new codes for the 1.2.12.
The bitrates you can change with custom firmware to 35mbps or ever bitrate you want. Here is a modified one in the first post to download in 35mbps, but sure you know how to do the update: https://dashcamtalk.com/forum/threads/xiaomi-yi-custom-firmware-with-lastest-revision.13557/
The new 1.2.12 now support resolution in 2,3k (2304x1296). If you need other resolutions not selectable in the App you have to set via script.
In the attachment are the adresses for the 1.2.12 fw and my modified movie script with config file, put both in the main path of micro sd and test it.
I changed the coring (14 to 104) in config file, the saturation and vibrance, gamma correction, enable 4GB splitting, making cardinfo.txt, beep at the end for notification. The lines with # in front are disabled but you can enable deleting the #. I use this script and a modified firmware for 35mbps. In normal situations and best quality i filming with 2304x1296 30fps 35mbps, in fast action situations and sometimes filming from car i use 1920x1080 60fps 35mbps. For good quality and more less file size i go to 1920x1080 30fps 35mbps.
Timelapse and burst mode not yet tested. Ihope i could help you a little bit.
MFG
gente
Now its working, thank you....i have no problems in downloading and unpacking, but i uploaded a new version!
I know, but waiting because there is not much changed.new firmware is out.
uploading ...1.12.13 custom? waiting for your excellent work
New Firmware release! First post Updated...
it gives more scene modes, nutseynut tested the modes, the 14th mode he means it have a better looking video.Hi gente, thanks for the file. Do you know what this command is doing?
#enable 14 scene mode
t cal -sc 14
MFG
gente
Do i put the 1.2.12-fw bitrate_addresses.txt and goprawn.config also in the root of sd card?
Or i need only the autoexec.ash ?
...also the 4GB splitting script?
now i tested the splitting 4GB script with 1.2.13 but no function, it splits the files in 2GB parts :
# set file size to 4GB
sleep 3
writew 0xC03A8620 0x2004
sleep 1
is doesn't work any more!
