Of course you lost script setting if change resolution via app, you'll have to leave 848x480p 200fps and restart camera if you want that workin, or simply add another line in script to start camera with that specific resolution, again if you change something you'll have to restart it..Yes, you are right, but doing this way the setting will not be lost if you change something by the app? I mean, start Yi, start recording at 200fps, than switch to 2K than switch back to 200fps, does the bitrate remain the same set by writew?
it still working? I've read in previous posts that in 1.2.13 doesn't work anymore...4GB splitting 1.2.13:
Code:#set file size to 4GB sleep 3 writew 0xC03A8520 0x2004 sleep 1
I'm using the same setting firmware and have no preview issue, try original 1.2.13 and look if you still have that problem..It seems that the 1.2.13 fw with 23A rev camera causes preview issues. The preview works only rarely for a short time, then gives black screen. Recording works ok. Tests done with high quality mode.
...it works 100% because its new adress for 1.2.13it still working? I've read in previous posts that in 1.2.13 doesn't work anymore...
Nice man!...it works 100% because its new adress for 1.2.13![]()
I don't get your point, what do you need exactly?Please for 1.2.13 file autoexec... or now hack firmware, for 2k video 30fps or high ?
Please help my)
try to add this line in autoexecIs there a way to disable the creation of the THM files?
I understand that if you reset the camera and never connect it to the app, you won't have THM files, but are there any other ways through autoexec?
lu_util exec rm /tmp/fuse_d/DCIM/100MEDIA/*_thm.mp4
try this line if still working in 1.2.13..Anyone know how to get the RAW image with script for 1.2.13 (z23L)?
t app test debug_dump 14
Code:t app test debug_dump 14
I've set preview mode to 2mbps cause initially me and other users are looking for better preview when shooting, you can change them yourself to lower value, take a look to video in first post, and using custom firmware you'll have to change these table address: 75 , 78 , 84 , 87 , 90 , 93 , 135 , 138 , 141 , 144
to a lower value instead of 2.0 ( ex. 1.0 or 0.5 )
http://www.xiaoyi.com/update/sports?lang=eng-engHow do i know what my build is?
I don't get what you asking for..and with what resolutions does it work?
Yesand i need to rename it then copy paste it to the sdcard and then turn on the camera?
Of course you can take a look to tutorial video in first post that explain how to do itP.S can i change the mbitrate to 60?
