Resolution 2k 1080pI don't get what you asking for..
P.S when i change all the MBits to 60 and all i click build rom from disk it says rfs builder failed!
what to do?
works for both of them and yes you can change resolution in app and keep bitrate...this work for PAL or just for ntsc?
can i change the resolution in the app and keep the 35mbps?
it strange I never had that error try again with an original firmware and be sure you won't touch temporary folder while editingResolution 2k 1080p
what to do?
tks great workworks for both of them and yes you can change resolution in app and keep bitrate...![]()
to set your own bitrate take a look to tutorial video in first post, you can't have more fps for those resolution cause it's an hardware limit...Hello,
I'm talking about 1080p 50fps , 60fps and can be set higher bitrate ? 50mbs ?
For 2k 30fps ? Higher bitrate ?
My recordings in resolutions:
31634kb / s - 1080p 50fps
33059kb / s - 2k 25fps
That's how they look, can raise anything from those kb / s ???
Regards and thanks![]()
Can you tell me whats and where is the original frimware that i can edit my self?it strange I never had that error try again with an original firmware and be sure you won't touch temporary folder while editing
be sure you download it correctly, after flash process that file should be auto-deleteduhmm, what am I doing wrong? Version 23L, on stock firmware 1.2.13, renamed file to firmware.bin, placed on root of sdcard; powered up the camera which starts flashing (multiple beeps), then stops. When I turn the camera on again, it just goes through the same process.
...format the card with fat32 32kb, you will see it works.i have a class 10 kingstone i tried format by the fone and using windows, my friend have the same camera and the same sdcard no problems.
Like gente said, it's probably a formatting issue. I had the same problem today with a Kingston 32GB class10. I'm on a mac right now, so I used "SDformatter" from sdcard.org with "Overwrite Format" checked, and "Logical Address Adjustment" set to "Yes". This tool is available for windows too. AFAIK apples DiskTool does not provide these kind of options. Seems to work perfectly. Also it solved a stuttering video issue when playing back straight from the card.i have a class 10 kingstone i tried format by the fone and using windows, my friend have the same camera and the same sdcard no problems.
