gente
- Aug 17, 2015
- Germany
you are welcome,
...you can use all scripts discussed and posted here. You can took a line of that script and put it to another script you like so you can set your own script. Use notepad++ it is shareware.
Mostly there is a description in autoexec what the command is standing for. Scripts are usually needed for adjustments cannot done by app. The 1080p 60fps you can set via app.
You can test that one in attachment to make the footages sharper, set noise to 500, set saturation, gamma, scene to potrait mode, exposure for dark and bright scenes and fix whitebalance and exposure.
Also set Filesplitting to 4GB and gives a beep when script is ready. That line you do not need set a hashtack before it. And also some resolutions and bitrates not setable by app.
2k resolution 30fps is better for sharpness 60fps makes the motions smoother for quick scenes, test it.
For bitrate and resolution viewing you can use "bitrate viewer" for free. Reading much here in forum would help and make you many things understanding.
