Fried
- Aug 10, 2015
- Italy
Did you rename it "firmware.bin"?Fried, i try upgrade your custom firmware for 23L and the cam not flash it, i missed something ?
Bin file in the root directory?
I think your battery is too low. Plug a power bank in or load your battery. I had this once, too. If your battery got under 40% power, it simply doesn't flash. Let me know, if it worked.On card root i have 2 folders
And inside Misc folder i have this bin file
Hmmm, an 8GB card shouldn't be the problem, unless it is damaged... how did you update last time or is it the first time?I think the problem is the card, is only 8 gb, i must buy another and try again, battery is fully charge.
With custom firmware is first time, normally i update by ota.Hmmm, an 8GB card shouldn't be the problem, unless it is damaged... how did you update last time or is it the first time?
first post...Hi guys, i got confused, where can i find custom firmware for z23l? thanks
in same place where these folders are you have to put firmware.binOn card root i have 2 folders
Did you use that one I uploaded in first post or not?It's worked for 23L 35mbit ! thank you Mate!
Raw script work on 35mbit firmwarewhat about Raw script ?
What's cc.exe??Can you guys still use cc.exe after upgrading to 1.2.12 fw? It connects, can access Control and Files, but Configuration gives me a blank page with no any configuration options...
