I have to international version I finally open up and refocus the lens. The open part is not hard it's just tedious job. I will test it tomorrow and compare before and after
anyone know what the problem is?
just installed it yesterday.
it's summer but early morning so it's not hot at all.
and I removed plastic protective film from the lens 🙂
you can see the outer edges are clear but center is fuzzy
I took the camera inside the house and recorded to see if lighting or dirty windshield had anything to do with it. even indoor, center is very fuzzy
pretty simple, took me less than 30min
hardest part was going back and back and forth between camera and computer to look at the footage to find the focus.
I took the camera apart (search youtube on how to)
used heat gun(hairdryer should work too) remove the hot glue holding the lens
then turning the lens little bit at a time to find the focus point.
I'm going to be tweaking it more until i find the sweet spot, then glue the lens back.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
