Hi, I received the Yi 2 months ago, but started playing with it this week, I was wondering if it's possible to set the resolution to 2560X1080 if possible, could anybody help me with it? Thank you very much for your time
#only for firmware v 1.2.0 2560x1080 upscale
#2304x1296 mode
writeb 0xC06CE446 0x02
#new resolution
writel 0xC05C1E09 0x04380A00
learning the scripts isnt finding file and copy onto sdcard.
if you want just ask for it.
I don't know what i'm doing wrong, I copy it to a text document and save it as autoexec.ash but it records at 1920x1080 what am I doing wrong? Thank you very much for your helpYou can try if you want, but you'll probably be dissapointed. It's just an upscale from 2304x1296 and looks streched.
Code:#only for firmware v 1.2.0 2560x1080 upscale #2304x1296 mode writeb 0xC06CE446 0x02 #new resolution writel 0xC05C1E09 0x04380A00
edit it with PSPAD and you will never again have problems![]()
descarga algun autoexec.ash de funnel y luego editalo a tu gusto ( si te sirve yo uso editpad lite y no me da problemas)I don't know what i'm doing wrong, I copy it to a text document and save it as autoexec.ash but it records at 1920x1080 what am I doing wrong? Thank you very much for your help
I tried to combine the noise reduction scrip into the resolution scrip but the camera go back to 1920x1080 mode. That's why I raise the question.In order to use noise reduction and resolution changing scripts do I have to combine them into one or can I drop them both into the root directory?
Hello, as a new Xiaomi Yi owner soon, i wondering what is the state of the hack right now. What are the advantage to use a script versus a hacked firmware files ?
If i use the script and remove it from the sd card, will the camera will be back to stock firmware ?
