how can i change the bitrate for 1080p/60 and 1080p/30 on 1..0.12. Are there any values ?
what about increasing framerate in 1080p by autoexec.ash
thank you
is it possible to increase framerate in this resolution?
or maybe increase resolution to 2.7k go pro mode? (2716x1524)
Thanx for the script! As I can see bitrate is fixed, so it's CBR mode. Do you know what bytes should be changed with writew for ABR/VBR?
Yes.
For 1.0.12 fw
#1080p 60fps 35 Mbit
writew 0xC05C28D6 0x420C
#1080p 60fps 30 Mbit
writew 0xC05C28D6 0x41F0
I'm not sure but probably not.
#1080p 60fps 35 Mbit CBR
writeb 0xC05C28D0 0x01
#then XXD0 is compress mode address
#then XXD6 is bitrate address
#1296p 30fps 35 Mbit CBR
writeb 0xC05C28A0 0x01
writew 0xC05C28A6 0x420C
#then XXA0 is compress mode address
#then XXA6 is bitrate address
Hi @funnel, Do I "guess" the 1296p right about the code 2? pls inform be return, thanks:
#set video resolution
#0x02=2304x1296 30fps
#0x03=1920x1080 60fps
#0x20=1920x1080 48fps
#0x06=1920x1080 30fps
#0x21=1920x1080 24fps
#0x0C=1600x1200 60fps
#0x23=1600x1200 48fps
#0x0D=1600x1200 30fps
#0x24=1600x1200 24fps
#0x16=1280x960 60fps
#0x25=1280x960 48fps
#0x17=1280x960 30fps
#0x26=1280x960 24fps
#0x0F=1280x720 60fps
#0x27=1280x720 48fps
#0x11=1280x720 30fps
#0x28=1280x720 24fps
#0x34=1280x720 120fps
#0x2A=856x480 24fps
#0x13=856x480 30fps
#0x38=856x480 120fps
#0x37=848x480 240fps
#0x12=848x480 60fps
#0x29=848x480 48fps
#0x19=728x400 30fps
#0x2C=640x480 24fps
#0x1C=640x480 30fps
#0x2B=640x480 48fps
#0x35=640x480 120fps
#0x36=640x480 240fps
#0x1A=640x360 30fps
#0x1B=640x360 30fps
#0x1D=440x240 30fps
#0x30=352x240 30fps
#0x2E=352x240 30fps
#0x2D=352x240 30fps
#0x2F=352x240 30fps
#buzzer on on boot means autoexec.ash executed
#set buzzer volume 1-150
t pwm 1 set_level 30
t pwm 1 enable
sleep 2
t pwm 1 disable
#begin
#end
#long beep means the commands executed
t pwm 1 enable
sleep 1
t pwm 1 disable
This are the scripts for all three modes CBR/ABR/VBR. I took order of the modes from the custom firmwares in the other thread.
For 1.0.12 fw
#1080p 60fps 30 Mbit CBR
#1080p 60fps 35 Mbit ABR
writeb 0xC05C28D0 0x02
#1080p 60fps 30 Mbit ABR
#1080p 60fps 35 Mbit VBR - cam default
writeb 0xC05C28D0 0x03
#1080p 60fps 30 Mbit VBR - cam default
Could you please give me the same scripts for 720p - 120fps?
Thanx
#1.0.12 1280x720 120fps 25Mbps
writew 0xC05C3206 0x41C8
#1.0.12 1280x720 120fps 30Mbps
writew 0xC05C3206 0x41F0
#1.0.12 1280x720 120fps 35Mbps
writew 0xC05C3206 0x420C
