Yi hacked resolution 2304x1296 30fps 35Mbits
Could you please copy the working script?
Code:
#Script created by xyc.sh 0.2.0
#CameraParams: 0 0 y n n
#UserSettings: y
#TimeLapseParams: 10 n y 12
#WARNING: Cannot read/access /tmp/fuse_d/autoexec.xyc
#1600x1200 60fps 35 mbps
writeb 0xC06CC426 0x0C
writew 0xC05C2092 0x420C
it strange it was the same you posted earlier... 😵
Anyway @Alisan.c if you add this line :
Code:
writel 0xC05C2D7C 0x04380780
you'll already have a 1600x1200 video stretched to 1920x1080 directly on card.. 😉
Ok so I just got started with the scripts (got the camera two days ago). The thing is I was excited to try with the 1600x1200 resolution, because the only one with a 4:3 format in the stock fw is the 1280x960, a bit low imo. I've managed to get this with the script:
Code:
After getting a quick sample and then comparing with the stock 960p resolution, the difference is inexistent. I mean the file has the resolution and bitrate specified, but I cannot see any difference on the quality (cropping in with sony vegas). Should there be any difference? Am I doing something wrong?
Why don't you try an example in really bright sunlight, with lots of diagonal lines, like power wires or a transmitter tower.
If you can't see anything, publish it here.
Ok so there is definitely a difference between the 1600x1200 and 1280x960 resolution, but I was expecting a bit more. I hope someone can manage some scripts for the 1920x1440.
btw I know the photo looks crap, still have to work on that sharpening and noise reduction
Hey guys I use this:
to stretch 1600x1200 60fps to 1920x1080 60fps. This is great in NTSC but what about PAL. I'm really stumped as to why it doesn't work in PAL mode.
Does anybody know what addresses I need to use it with PAL?
Try this one:
writel 0xC05C3204 0x04380780
It's in 25Fps
#set ISO and Exposure
# exp: [iso_idx][exp_idx][gain_idx], 0 auto
t ia2 -ae exp 25600 1200 0
is there a way to apply this to videos?
Thank you
1600x1200 30fps save up to 50mbits
Can you help me to get 1600x1200, 30fps with 50 or better 40mbits?
Firmware 1.2.13 would be nice, or any of the 1.2 series.
I tried but I was not succesfull.
If you could provide the autoexec.ash it would be very nice!
Thanks!
Thanks!
choose one!
#ok_1600x1200 60fps 30 mbps
writew 0xC05C2092 0x41F0
#1600x1200 60fps 50 mbps
writew 0xC05C2092 0x4248
#ok_1600x1200 60fps 45 mbps
writew 0xC05C2092 0x4234
#ok_1600x1200 30 fps 50 mbps
writeb 0xC06CC426 0x0D
writew 0xC05C20C2 0x4248
#ok_1600x1200 30 fps 45 mbps
writew 0xC05C20C2 0x4234
