luckylz
- Apr 8, 2015
- China
Hey guys, firmware 1.1.3 and app 1.8 will have 2K resolution:
when firmware 1.1.3 will be release?
新的1.1.3固件什么时候发布?
Alright Funnel, this is a great and very clear set of instructions, it's taken me (with 0 experience) 90% of the way there.
Hi Samiluo,Hey guys, firmware 1.1.3 and app 1.8 will have 2K resolution:
Video file: 401M
by using app 1.8 beta, firmware 1.1.3
I checked today finally shows 2k resolution guys just enjoy
Hi Samiluo,
First of all, thanks for your sharing. However, inside youtube, I can only choose the 1080p format for viewing. I have to use some kinds of youtube downloader to get the 2k quality video. the file size has reduced down to 10Mbps. I believe youtube has re-compress the file again. I believe it is better to use Dropbox for sharing.
Besides, can you share the link where we can download the beta firmware and App? Thanks in advance.
rlpc8
Thanks Funnel. That explanation worked, I can (very slowly) navigate through this stuff now. I appreciate your help.There is a file PRI.a7h, open it with a text editor and you'll see the loadaddress=C0100000. You need to add this to the address. Example 0x004C2840 + 0xC0100000 = 0xC05C2840
Then you can try with something like "readew 0xC05C2840 > ww.txt" from an autoexec.ash script to see what's there. writeb is write byte, writew - write word(2bytes), writel (4bytes), readb, readw, readl.
For resoultion you can try with my script on githhub under experimental for 1.1.0 and change the hex number for your desired size, but it just upscales, downscales.
"if i am smart" well that's the big question isn't it! Alright, I'll give it a shotMost of them were already found by other people. For the others I was lucky and found them pretty quick, maybe on the 4th or 5th try. If you are smart you could do a longer script that changes a bitrate, records a few seconds video, stop recording, change second bitrate, repeat for all addresses you want to check. Then look at the recodings and find out which one it the correct one.
It works if you use "t app key shutter", I have not tested "shutter_rel". It is really useful for custom time-lapses, and if it's combined with "reboot yes" it's possible to create mega time-lapses.The "t app key shutter" and "t app key shutter_rel" commands simulate the shutter key press and key_release.
Something like
sleep 8
t app key shutter
sleep 10
t app key shutter
should make a 10 sec video, first 8 sec is wait for cam boot. The cam must be set to boot in video mode obviusly. Didn't try but it should work.
Something like
sleep 8
t app key shutter
I'm trying to discover if the Yi can do 1920x1440, 48 or 60fps, without upscaling. I'm also trying to find the bitrate address of 1600x1200 48 and 30fps. Would it be the same as 1600x1200 60fps? Thanks for all your help today, I burned a few hours but I still need practice creating autoexecs.Each firmware it's a different address. Which resolution do you want to set the bitrate?
Thanks Funnel! This is in FW 1.1.0, correct? I'll go and update my 18 cameras now1600 x 1200 48 should be no. 105 in AFT, 1600x1200 30fps no.39.
1920 x 1440 is not there, only 2560 x 1440.
