I return on 1.0.9 firmware, 4k@30fps on my copter!
Excellent.
Download the script directly by clicking "Raw" on github ans Save as... on SD card. Could be a problem in your text editor.
Thanks, I found the option.How can I select this option in Android APP? Use the 1920x1080 30fps option?
2k, sorry
2k works great with 1.1.0 so what was the reason to downgrade to 1.0.9?2k, sorry![]()
1.1.0 has freezing problems2k works great with 1.1.0 so what was the reason to downgrade to 1.0.9?
your tf card's problem. if you use slow card, then upgrade it; if you use fast card, then format it again and test!did someone noticed gaps between the generated video files? Im aktually testing 1080 50p with 30mbis and noticed near 200ms gaps between the videos. Maybe with 1296 at 35mbits it could be worse?
Didn't notice any with my white 221 cam.1.1.0 has freezing problems
Yeah, and BTW when the camera is doing some continuous writing like capturing videos to some TLC flash cards (even some faster cards with Class10 or UHS-1 certificates), it may crashes sometime.your tf card's problem. if you use slow card, then upgrade it; if you use fast card, then format it again and test!
I am using firmware 1.1 and added the autoexec.ash to the root of the sd card but nothing happens. I dont have anychanges in the android app either. Can anyone provide me with detail instructions on how to use the autoexec.ash in conjunction with app. Thanks.
Did you edit the script, or did you use a editor to save the script?
Remember the camera only can recognize the script files in Unix line break format.
See this: http://www.editpadpro.com/tricklinebreak.html
BTW if you want to edit the file on Windows platform, you can use Notepad++ and save it as a Unix text file.
