I've created a program to allow mode and setting changes without connecting to a phone and without needing to reboot. I've only tested it with 1.2.12 and 1.2.13 firmware so I can't guarantee it will work on anything else.
Download:
https://drive.google.com/file/d/0B4toKKKJwI9jOFlJbkg4bE5MaWc/view?usp=sharing
Install:
The files in the zip need to be extracted and placed in the root directory of your camera's micro sd card.
Setup:
Modes, settings, and LED blinking behavior can be modified by editing yi_plus.json.
Using:
Single click power button:
Known Issues:
- sometimes doesn't work. need to turn camera off and back on. maybe an issue with the wifi trick?
- wifi LED blinks but but wifi is not on
- pressing wifi button will turn wifi off and yi_plus will stop working
- pressing wifi button again will turn wifi on and allow connection from phone/tablet
- must power cycle camera after using wifi
- might not be able to upgrade firmware while yi_plus is running (might have to switch to a different sd card)
Donate:
If you like it and want to donate, you can do so via this link:
https://goo.gl/ApYN94
Download:
Install:
Setup:
Using:
- Normal behavior - switch between capture and record
- If in capture mode, goes to next yi_plus capture mode listed in yi_plus.json
- If in record mode, goes to next yi_plus record mode listed in yi_plus.json
Known Issues:
Donate:
